I have a RFXcom dimmer connected with a lightbulb. The dimmer operates with one simple ON and OFF command to switch the light on and off. To activate the dimming it requires a burst of 6 ON or OFF commands.
A brief description of what I’m trying to accomplish here. On both the HABpanel and Basic UI I would like to have one switch for ON/OFF and 2 buttons to increase/decrease the light intensity.
I managed to create a working solution for the HABpanel:
On the Basic UI there is an little issue with the setpoint function. In the sitemap the item is configured with label=“Lamp 3 Intensiteit []”, but it still displays the value.
When the webpage is refreshed (F5) the value disappears…
… until an up/down button is pressed. Than the value 0 appears again.
To be positive, the dimming does work. If anyone knows how to hide the value I would like to know.
Any comment on this implementation is greatly appreciated, also tips to simplify the rules are very welcome.
Here are my used items, sitemap and rules.
Items:
- Item Plus_FF_LR_L3 and Minus_FF_LR_L3 are used only for the up/down buttons in the HABpanel.
- Item Power_FF_LR_L3 is used in the HABpanel and Basic UI.
- Item Dimm_FF_LR_L3 is used only for the up/down buttons in the Basic UI.
Switch Wallplug_FF_LR_L3 "Lamp 3" <light> { channel="rfxcom:lighting4:76261ede:382280:command" }
Switch Power_FF_LR_L3 "Lamp 3" <light>
Switch Plus_FF_LR_L3 "Lamp 3" <lightbulb>
Switch Minus_FF_LR_L3 "Lamp 3" <lightbulb>
Number Dimm_FF_LR_L3 "Lamp 3" <lightbulb>
Sitemap:
Switch item=Power_FF_LR_L3 label="Lamp 3"
Setpoint item=Dimm_FF_LR_L3 label="Lamp 3 Intensiteit []" minValue=-1 maxValue=1 step=1 visibility=[Power_FF_LR_L3==ON]
Rules:
// Dimmer light
rule "Lamp 3 Power ON"
Item Power_FF_LR_L3 changed from OFF to ON
then {
Wallplug_FF_LR_L3.sendCommand(ON)
Dimm_FF_LR_L3.sendCommand("0")
rule "Lamp 3 Power OFF"
Item Power_FF_LR_L3 changed from ON to OFF
Wallplug_FF_LR_L3.sendCommand(OFF)
rule "Lamp 3 Dimmer Plus"
Item Plus_FF_LR_L3 changed from OFF to ON
if (Power_FF_LR_L3.state == ON) {
Plus_FF_LR_L3.sendCommand(OFF)
else {
Power_FF_LR_L3.sendCommand(ON)
rule "Lamp 3 Dimmer +"
Item Dimm_FF_LR_L3 changed to "1"
else {
rule "Lamp 3 Dimmer Min"
Item Minus_FF_LR_L3 changed from OFF to ON
Minus_FF_LR_L3.sendCommand(OFF)
else {
rule "Lamp 3 Dimmer -"
Item Dimm_FF_LR_L3 changed to "-1"
else {
