it is a very simple question, bat i did not found a solution in this community; on which place in a GUI-based rule to declare the import, like:
“import org.eclipse.smarthome.model.script.ScriptServiceUtil”
Discussion -
Of note -
You can’t do imports in a GUI DSL rule
There are no smarthome
components in OH3
Not only that but ESH generally required Java 8 and OH3 uses Java 11.
no i founded, sorry
Sure, if you had read the discussion I pointed you at - it tells you exactly what to do.
