The contributors have done a remarkable job of making installation straight-forward. But it’s really important that the application “play nice with others.” Whether running under apache or nginx, an application path is an essential element. Every path generated for the client should be relative and every incoming request should have the path prefix removed prior to processing. I would have thought that the node.js framework would handle this, but I must be mistaken. I’d be willing to free up some cycles if others consider this worth the effort. Feedback invited.
@Phil_Selby
If you have improvements, feel free to add them to github as issue/enhancement. I actually like your step to first discuss here.
Let me know what you have in mind more detailed…
