I am Using a Raspberry Pi 3+ with openhabian. One is String where the up time is saved and the other one is a switch where the up time got resetted.
.itmes:
String Wetterstation_Online "up time [%s clock]" <time>
String Wetterstation_Reset "up time Reset"
.sitemap:
Text item=Wetterstation_Online
Switch item=Wetterstation_Reset mappings=[Reset="Reset"]
Is it possible to get the up time in front of the Reset-Button? Like this:
But - you can put Wetterstation_Online into your sitemap as a Switch, with the button mapping.
That just looks like what you want, but doesn’t act like you want. When you click reset, a string command "Reset" is sent to Wetterstation_Online.
Set autoupdate false for Wetterstation_Online so that the command does not overwrite your datetime.
Make a rule that listens for commands to Wetterstation_Online, and have it do what you want.
You’ll need to make sure that whatever usually populates Wetterstation_Online does so by updates and not commands.
Hey,
I got it, but when I write behind my Item {autoupdate="false"} it isn’t updating in the sitemap.
.items:
String Wetterstation_Online "Online seit [%s Uhr]" <time>
.rules:
rule "Wetterstation_online"
Item Wetterstation_Online received command "Reset"
Wetterstation_Online.sendCommand(Zeit.state.format("%1$td.%1$tm.%1$tY, %1$tH:%1$tM"))
//Wetterstation_Online.postUpdate(now.toString("dd.MM.yyyy, HH:mm"))
I got a second “problem” with the current time. I get my time over the ntp-binding with a 30s refresh. It is possible to get the current update timestamp out of the the system time? I know there is a command new DateTimeType() or now.getHourOfDay, ..., but I dont know how to transform (dd:mm:yyyy, HH:MM) this in the current time.
At the moment I write my date+time out of the ntp-bindings, which updating every 30s. When it is now 12:30 and 10s is writing the last ntp update into the item (As example 12:29 50s) because it is updating (as example at 20s and 50s per minute).
I search a function where I can write the current system date and time into my strings (not only for this)
My current sitemap clock got his data from the ntp-binding too, so it got refreshed after 30s. The problem of this is, when the system startup is at 1s of a minute, the next update is at 31s. There is a time different of 31s to the correct time.
