Thanks for sharing. I believe others have developed similar pre-parsers but I don’t think anyone has posted on yet.
Some comments, mainly for future readers who come along later:
Be aware that the ability to use libraries and reusable code is one of the drivers behind the creation of the Experimental Rules Engine. There is also the JSR223 add-on that lets you write Rules using Jython, JavaScript, or Groovy. So if one truely wants all the features of a general purpose programming language instead of some of the designed in limitations of the Rules DSL they can use either of these.
There is also support for Scripts, though they have a limitation that you cannot pass values into the script which greatly reduces their utility.
There used to be a problem with having global variables of the same name in multiple rules files. I don’t know if this is still the case. However, there is absolutely a problem with having Rules with the same name so this script would not work to include whole Rules unless you edit the .rules files after the include.
One can often avoid the need to do includes like this at all by organizing your Rules by function rather than location (e.g. have lighting.rules rather than bedroom.rules). For cross-cutting concerns like alerting or calculating time of day you can add in Design Pattern: Separation of Behaviors which centralizes all that logic into one set of Rules, again aleviating the need for performing includes like this.
