I am setting up a new Openhab 2.4 system but i have some problems with my zwave devices. I have several wall switches Oomi FT136 with deviceID 016A:0003:008C::1.0 listed as unknown devices after a auto discover search. After some web searchs I found that my devices are not the same Reference ID as the “standard” device listed in the openhab database:
There is no manual in internet about this switch but i managed to find one and i have scanned it for you. Here is the link: http://www.foromtb.com/tmp/domux.pdf
If you need something else, please let me know it.
I have a similar problem with a Domux “HS1MS-Z Smart Motion Sensor”. It was working like a charm for a couple of years but when battery depleted and I changed it it no longer worked, I tried excluding and including serveral times but without success. I was about to give up when I spot this thread
During last days it was recognised as Heiman Technology Co. Ltd db reference 736, but I wasn’t receiving events from it despite it appeared as online
Today I tried for the last time before throw it away but it does not even recognise as Heiman device, it just say (0082:6015:020D::2.0) ") is not in the database.
As I updated OpenHAB to 2.5.10 recently, I wonder is it is something might be changed recently
Try waking the device up. I think the message you have quoted here with 6015:020D is the standard documentation message, and not related to your device. Do you have a type/id shown in the properties of the device? If not, I suspect that the device is just not discovered.
I can only really repeat what I said above. Please try waking the device up. The discovery information is not know, so discovery has not completed and therefore the device type is not known.
