Accented characters sent by openHAB MQTT binding appear not to be incoded to utf8 as per MQTT 3.1.1 specification.
For example, calling:
sendCommand(myKodi_artist, "Accentué")
or sendCommand(myKodi_artist, "Accentu\u00E9")
properly sets the myKodi_artist item
BUT sends a message on MQTT bus where the text is not encoded to utf8.
As a result, listener clients close connection as recommended in the MQTT 3.1.1 specification when a malformed message is received. And this is crashing all my HA system.
I use the event bus mqtt bridge to connect openhab v1 with openhab v2
and openhab1 does not send the letters properly (Get <?> symbols). Also if I manually publish to a topic by external client, openahb2 is receiving it like ? symbols.
there is nothing special logged even with there settings
2018-05-08 23:45:05.112 [vent.ItemStateChangedEvent] - Mreza_Athlon_probe changed from NULL to ON
2018-05-08 23:45:05.618 [vent.ItemStateChangedEvent] - Msg2 changed from NULL to ???????????????? 2 ????????????????
2018-05-08 23:45:05.891 [vent.ItemStateChangedEvent] - Location_Phone2_Mqtt_rabota changed from NULL to OFF
2018-05-08 23:45:06.518 [vent.ItemStateChangedEvent] - Location_Phone2_Mqtt_centar changed from NULL to OFF
Msg2 should become “Кирилица 2 Латиница”
2018-05-08 23:43:39.159 [INFO ] [.core.internal.i18n.I18nProviderImpl] - Locale set to mk_MK, Location set to 41.997346199 999996,21.4279956, Time zone set to Europe/Skopje
2018-05-08 23:43:40.090 [INFO ] [er.internal.HomeBuilderDashboardTile] - Started Home Builder at /homebuilder
2018-05-08 23:43:41.134 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at http://192.168.5.116:8080
2018-05-08 23:43:41.147 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at https://192.168.5.116:8443
2018-05-08 23:43:48.526 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'items.items'
2018-05-08 23:43:54.719 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-05-08 23:43:56.282 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'default.sitemap'
2018-05-08 23:44:01.823 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-05-08 23:44:02.184 [INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
2018-05-08 23:44:02.231 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-05-08 23:44:02.302 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2018-05-08 23:44:02.557 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-05-08 23:44:02.821 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Starting MQTT Service...
2018-05-08 23:44:02.823 [DEBUG] [org.openhab.io.transport.mqtt ] - ServiceEvent REGISTERED - {org.openhab.io.transport.mqtt.MqttService, org.osgi.service.cm.ManagedService}={service.pid=org.openhab.mqtt, component.name=MQTT Connection Service, component.id=227, service.id=355, service.bundleid=241, service.scope=bundle} - org.openhab.io.transport.mqtt
2018-05-08 23:44:02.859 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTING - org.openhab.io.transport.mqtt
2018-05-08 23:44:02.897 [DEBUG] [org.openhab.io.transport.mqtt ] - BundleEvent STARTED - org.openhab.io.transport.mqtt
2018-05-08 23:44:02.896 [DEBUG] [penhab.io.transport.mqtt.MqttService] - Setting last will: [class org.openhab.io.transport.mqtt.MqttWillAndTestament] Send 'OFF' to topic 'ohab/@' retained using qos mode 1
2018-05-08 23:44:02.898 [INFO ] [penhab.io.transport.mqtt.MqttService] - MQTT Service initialization completed.
2018-05-08 23:44:02.911 [INFO ] [t.mqtt.internal.MqttBrokerConnection] - Starting MQTT broker connection 'ohabssl'
2018-05-08 23:44:02.918 [DEBUG] [t.mqtt.internal.MqttBrokerConnection] - Creating new client for 'ssl://192.168.5.8:8883' using id 'glusec-openhab2' and file store '/var/lib/openhab2/tmp/ohabssl'
2018-05-08 23:44:03.188 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:broker
2018-05-08 23:44:03.191 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:topic
2018-05-08 23:44:03.193 [WARN ] [mqtt.internal.MqttPersistenceService] - mqtt-persistence:message
2018-05-08 23:44:03.528 [DEBUG] [org.openhab.binding.mqtt ] - BundleEvent STARTING - org.openhab.binding.mqtt
2018-05-08 23:44:03.550 [DEBUG] [.binding.mqtt.internal.MqttActivator] - MQTT binding has been started.
2018-05-08 23:44:03.649 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.osgi.service.event.EventHandler}={event.topics=openhab/*, component.name=org.openhab.binding.mqtt.MqttItemBinding, component.id=235, service .id=372, service.bundleid=275, service.scope=bundle} - org.openhab.binding.mqtt
2018-05-08 23:44:03.653 [DEBUG] [org.openhab.binding.mqtt ] - ServiceEvent REGISTERED - {org.openhab.model.item.binding.BindingConfigReader, org.openhab.binding.mqtt.MqttBindingProvider}={component.name=org.openhab.binding.mqtt.gener icbindingprovider, component.id=236, service.id=371, service.bundleid=275, service.scope=bundle} - org.openhab.binding.mqtt
