I have a very simple energy.rules files and I receive errors at runtime
import org.openhab.core.library.types.*
val Number kWh_cost = 0.1206
val Number kWh_co2 = 0.09
rule "General switch off"
Presence changed from ON to OFF
logInfo("Shutting down elements")
sendCommand(HueToggle1, OFF)
sendCommand(HueToggle2, OFF)
sendCommand(HueToggle3, OFF)
sendCommand(PowerSwitch4, OFF)
sendCommand(PowerSwitch5, OFF)
rule "Update energy type"
Time cron "0 0 * * * ?"
var hour = now.getHourOfDay
if (((hour >= 2) && (hour < 7)) || ((hour >= 14) && (hour < 17))) {
EnergyType.postUpdate("HCreuses")
} else {
EnergyType.postUpdate("HPleines")
rule "Update meter costs"
Item gKwh changed
TotalEnergyEuro.postUpdate((gKwh.state as DecimalType) * kWh_cost)
TotalEnergyCo2.postUpdate((gKwh.state as DecimalType) * kWh_co2)
And I get
2016-02-14 20:02:00.037 [ERROR] [.o.m.r.i.engine.ExecuteRuleJob] - Error during the execution of rule UpdateEnergyType
java.lang.IndexOutOfBoundsException: Index: 1, Size: 1
at java.util.ArrayList.rangeCheck(ArrayList.java:653) ~[na:1.8.0_73]
at java.util.ArrayList.get(ArrayList.java:429) ~[na:1.8.0_73]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluateArgumentExpressions(XbaseInterpreter.java:750) ~[na:na]
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._featureCallOperation(XbaseInterpreter.java:712) ~[na:na]
at sun.reflect.GeneratedMethodAccessor49.invoke(Unknown Source) ~[na:na]
Any idea where the list is ?
Thanks-
