My previous openHAB installation on RP3B+ broke and I was not able to recover it.
So I started a new clean install, got through all the regular hassles with RP3B+ and OpenHABianPi like wifi not connecting and many other issues, untill finally I was able to get through the whole installation process without any problems, everything seems to be in place except for 1 “little” detail.
With monitor behind the RaspberryPi I can see an infinite loop of:
[ OK ] Started openHAB 2 - empowering the smart home.
[ OK ] Stopped openHAB 2 - empowering the smart home.
And so on … ( I guess you get the idea)
I have no idea what could be causing this but accessing openhab via web is not possible.
2019-03-20_22:29:24_EET [openHABian] Adding an openHAB dashboard tile for 'frontail'... OK
2019-03-20_22:29:24_EET [openHABian] Execution of 'openhabian-setup.sh unattended' completed.
2019-03-20_22:29:24_EET [openHABian] Waiting for openHAB to become ready...
There is /opt/openHABian-install-successful file but no afterfirstboot.lock file anywhere but also no in progress or failed files, and every time raspberry restarts it goes through all the first-boot script things…
Tried almost everything by now and have a huge headache
Re installed with clean image 4 times, manually created afterfirstboot.lock file, now reran FireMotD instals and configs all the different ways, installed new java, updated openhab2-addons, removed openhab2-addons and openhab2, reinstalled them both to see if anything changes… nothing…
I did this and seems most of the errors have disappeared, still no openhab @openhabianpi:8080 connection refused, but I’ll get over that I’m pretty sure.
Since I’ve done so much stuff here now that I my raspberry could be quite bloated and not the best setup, I’ll do one more fresh clean instal where your symlink is in first-boot.sh and see if I get nice install results with this or not.
I did however install everything with cable attached and only afterwards set up wifi. wifi works and everything works just when starting up I get dhcpcd service failed error and status is also:
dhcpcd.service - dhcpcd on all interfaces
Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled; vendor preset: enabled)
Drop-In: /etc/systemd/system/dhcpcd.service.d
└─wait.conf
Active: failed (Result: exit-code) since Thu 2019-03-21 16:54:34 EET; 36min ago
Process: 343 ExecStart=/usr/lib/dhcpcd5/dhcpcd -q -w (code=exited, status=6)
Mar 21 16:54:34 openHABianPi systemd[1]: Starting dhcpcd on all interfaces...
Mar 21 16:54:34 openHABianPi dhcpcd[343]: Not running dhcpcd because /etc/network/interfaces
Mar 21 16:54:34 openHABianPi dhcpcd[343]: defines some interfaces that will use a
Mar 21 16:54:34 openHABianPi dhcpcd[343]: DHCP client or static address
Mar 21 16:54:34 openHABianPi systemd[1]: dhcpcd.service: Control process exited, code=exited status=6
Mar 21 16:54:34 openHABianPi systemd[1]: Failed to start dhcpcd on all interfaces.
Mar 21 16:54:34 openHABianPi systemd[1]: dhcpcd.service: Unit entered failed state.
Mar 21 16:54:34 openHABianPi systemd[1]: dhcpcd.service: Failed with result 'exit-code'.
Warning: dhcpcd.service changed on disk. Run 'systemctl daemon-reload' to reload units.
