Influx DB - Batch could not be sent. Data will be lost java.lang.RuntimeException: {"error":"timeout"}
I have just migrated OH2 from a Pi3B to a Pi4, including all influxdb data, grafana, mosquitto and other programs.
After the migration I noticed some InfluxDB timeout errors in the openhab log:
2020-03-25 11:08:45.945 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
        at org.influxdb.impl.InfluxDBErrorHandler.handleError(InfluxDBErrorHandler.java:19) ~[influxdb-java-2.2.jar:?]
        at retrofit.RestAdapter$RestHandler.invoke(RestAdapter.java:242) ~[retrofit-1.9.0.jar:?]
        at org.influxdb.impl.$Proxy171.writePoints(Unknown Source) ~[?:?]
        at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:151) ~[influxdb-java-2.2.jar:?]
        at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:171) [influxdb-java-2.2.jar:?]
        at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:144) [influxdb-java-2.2.jar:?]
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_222]
        at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_222]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_222]
        at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_222]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
2020-03-25 11:50:16.245 [ERROR] [org.influxdb.impl.BatchProcessor    ] - Batch could not be sent. Data will be lost
These errors appear about 5-6 times per day.
The SD card is a 128 GB brand new card. There are no other errors in /var/log/messages.
The output of dmesg shows an error related to a file system cookie:
[   15.348610] FS-Cache: Duplicate cookie detected
[   15.348628] FS-Cache: O-cookie c=(ptrval) [p=(ptrval) fl=222 nc=0 na=1]
[   15.348638] FS-Cache: O-cookie d=(ptrval) n=(ptrval)
[   15.348649] FS-Cache: O-key=[8] '020001bd0a0000fd'
[   15.348684] FS-Cache: N-cookie c=(ptrval) [p=(ptrval) fl=2 nc=0 na=1]
[   15.348693] FS-Cache: N-cookie d=(ptrval) n=(ptrval)
[   15.348702] FS-Cache: N-key=[8] '020001bd0a0000fd'
Is there any solution for this?
Thanks,
Cristian
