Hi all, running openhab 3.4.1 on a rpi4 w SSD, zram not installed
I’m running now to an issue “InfluxDB Error: Bad Gateway” at the grafana graphs (IP:3000)
sudo journalctl -u influxdb.service
gives me the following
**openhabian@openhabian**:**~ $** systemctl status influxdb.service
**●** influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: **failed** (Result: exit-code) since Sun 2023-01-15 11:44:18 CET; 1min 35s ago
Docs: https://docs.influxdata.com/influxdb/
Process: 814 ExecStart=/usr/lib/influxdb/scripts/influxd-systemd-start.sh **(code=exited, status=1/FAILURE)**
Jan 15 11:44:18 openhabian systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Jan 15 11:44:18 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
Jan 15 11:44:18 openhabian systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Jan 15 11:44:18 openhabian systemd[1]: **influxdb.service: Start request repeated too quickly.**
Jan 15 11:44:18 openhabian systemd[1]: **influxdb.service: Failed with result 'exit-code'.**
Jan 15 11:44:18 openhabian systemd[1]: **Failed to start InfluxDB is an open-source, distributed, time series database.**
and later
-- Logs begin at Sun 2023-01-15 11:13:19 CET, end at Sun 2023-01-15 11:51:52 CET. --
Jan 15 11:21:46 openhabian systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Jan 15 11:21:46 openhabian influxd-systemd-start.sh[866]: /usr/lib/influxdb/scripts/influxd-systemd-start.sh: line 4: /var/lib/influxdb/influxd.pid: Permission denie
Jan 15 11:21:46 openhabian systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Failed with result 'exit-code'.
Jan 15 11:21:47 openhabian systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 1.
Jan 15 11:21:47 openhabian systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Jan 15 11:21:47 openhabian systemd[1]: Starting InfluxDB is an open-source, distributed, time series database...
Jan 15 11:21:47 openhabian influxd-systemd-start.sh[900]: /usr/lib/influxdb/scripts/influxd-systemd-start.sh: line 4: /var/lib/influxdb/influxd.pid: Permission denie
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Control process exited, code=exited, status=1/FAILURE
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 2.
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 3.
Jan 15 11:21:47 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 4.
Jan 15 11:21:48 openhabian systemd[1]: Failed to start InfluxDB is an open-source, distributed, time series database.
Jan 15 11:21:48 openhabian systemd[1]: influxdb.service: Service RestartSec=100ms expired, scheduling restart.
Jan 15 11:21:48 openhabian systemd[1]: influxdb.service: Scheduled restart job, restart counter is at 5.
Jan 15 11:21:48 openhabian systemd[1]: Stopped InfluxDB is an open-source, distributed, time series database.
Jan 15 11:21:48 openhabian systemd[1]: influxdb.service: Start request repeated too quickly.
Jan 15 11:21:48 openhabian systemd[1]: influxdb.service: Failed with result 'exit-code'.
Any ideas how to fix?
Regards, René
