Influx Persistence log issue after adding a new item to persistence log
i’m on latest 3.02 release and generally persistence works fine with influx 1.86. However, after adding an existing item to the persistence file i now receive a bunch of error messages without a reason. In general, no clue what could be the problem mentioning line 1 that does not even hold complex configuration.
Tried to reboot already, but same issue again…maybe i’m blind and you see something. also removed this simple Wimberg_TempTop1011 item…error keeps coming, so i do not believe its really a “the new” item issue…
Here is the persistence file:
Strategies {
        everyMinute : "0 * * * * ?"
Items {
        RH_Basement,LRMotionSensor_Temperature,PufferState,RestO2state,EGthermo,DGthermo : strategy = everyMinute
        Hofer_Temps*,PowerMap*,EGvlauf,DGvlauf,Pool_Power,EVchargePower : strategy = everyMinute
        LivingRoom_Power,PowerTotal,VeACkWhFor,VeACkWhRev,EnergyImpDaily,EnergyExpDaily,NG4EnergyExp,NG4EnergyExpDaily,PVisland_Power,PvXL_Power,Devolo3_Power,AirCon_Power,AirDryer_Power,TV_Power,PVislandVolt : strategy = everyMinute
        DBtemp,YRtemp,NG4Top1temp,NG4Top1BathTemp,BathESPtemp,BaseESPtemp,AtticTemp,BaseESPhum,Base2ESPhum,Base2ESPtemp,TuyaSensor01_temp : strategy = everyMinute
        PVng5sum,PvMicro_Power,NG4power,FibGarage_Power,BathESPvcc,SmartDisplay01vcc,SmartDisplay02vcc,AtticVcc,NG4Top1vcc,DBvcc,YRvcc,CollectorTemp : strategy = everyMinute
        NG5_JeelinkOutside_Temperature,NG5_JeelinkOutsideTX22_Rain,NG5_JeelinkFridge_Temperature,NG5_JeelinkLivingRoom_Temperature,NG5_JeelinkOutsideTX22_Temperature,NG5_JeelinkOutside_Humidity,NG5_JeelinkTX25_TempEXT,NG5_JeelinkOutside$
        Wimberg_TempTop9,Wimberg_TempTop1011, EPsolar_PVpower,EPsolar_CASEtemp,EPsolar_BATvolt,Rain_1h : strategy = everyMinute
        BigSmartEPD1vcc,BigSmartEPD2vcc,BigSmartEPD3vcc,BigSmartEPD4vcc,BigSmartEPD5vcc : strategy = everyMinute
        VeBatSoc,VeBatTemp,VeBatPower,VeMP2Temp : strategy = everyMinute
and here the error log that shows up as soon as i save/exit the editor @closing peresistence file…
2021-09-16 00:05:27.571 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'influxdb.persist'
2021-09-16 00:05:28.695 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@1b0901f': error parsing query: found ALL, expected identifier at line 1, char 48
org.influxdb.InfluxDBException: error parsing query: found ALL, expected identifier at line 1, char 48
        at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:161) ~[?:?]
        at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[?:?]
        at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[?:?]
        at org.influxdb.impl.InfluxDBImpl.executeQuery(InfluxDBImpl.java:814) ~[?:?]
        at org.influxdb.impl.InfluxDBImpl.query(InfluxDBImpl.java:714) ~[?:?]
        at org.openhab.persistence.influxdb.internal.influx1.InfluxDB1RepositoryImpl.query(InfluxDB1RepositoryImpl.java:155) ~[?:?]
        at org.openhab.persistence.influxdb.InfluxDBPersistenceService.query(InfluxDBPersistenceService.java:231) ~[?:?]
        at jdk.internal.reflect.GeneratedMethodAccessor177.invoke(Unknown Source) ~[?:?]
        at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
        at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
        at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
2021-09-16 00:05:28.714 [ERROR] [ence.internal.PersistenceManagerImpl] - Exception occurred while querying persistence service 'influxdb': error parsing query: found ALL, expected identifier at line 1, char 48
is there any fix for this?
Recently i added a new item to the persistence service (influxdb 1.8.6) and again a log similar to the one above is coming. I’m on v3.2 M5
I am having the same error message in Openhab 3.2.
