Ver: 3.0.2 Synology Docker
Hi
I’m struggling with a one line rule that is throwing the following error:
12:08:00.187 [ERROR] [.internal.handler.ScriptActionHandler] - Script execution of rule with UID 'rCalcAverageRain2Hours' failed: Weather_ActualRain_avg. ___ postUpdate(Weather_CurrentRainVolume.averageSince(now().minusMinutes(120),"influxdb"))
Ambiguous feature call.
The extension methods
postUpdate(Item, State) in BusEvent and
postUpdate(Item, Number) in BusEvent
both match.; line 1, column 23, length 10
The rule is:
Weather_ActualRain_avg.postUpdate(Weather_CurrentRainVolume.averageSince(now().minusMinutes(120),"influxdb"))
Weather_CurrentRainVolume is successfully persisted in Influx:
While I initially defined the items as length quantity type, I changed them both to Number (no quantity type) as a troubleshooting step.
Am I missing a casting / qualifier in the rule or is it something else? It wasn’t clear from looking at the many posts on similar problems.
Many thanks
