Running openhab 4.3.3 on ubuntu 24.10 hosted by KVM.
Persistence using influxdb Version 2.7.12
Thanks you all for this nice soltion, it runs very well!
The following command always produces the same error (token is filled with some xxx’s)
influx backup /tmp -t _zxxxj89rBefRKErPS9Z9L7YxxxriWTcW5YNdxxxxb88q5jNg0y0EfgYl8lBC7wCCaKTfHBkiUaExw3XAVg==
–> Error: failed to backup metadata: failed to download metadata snapshot: 401 Unauthorized: read:authorizations is unauthorized
I’ve tried three different token, the root token generated at installation, and two token generated with the UI (all access, custom with all read/write).
Thanks for any ideas.
Falk
