InfluxDB + Grafana installation
Tags: #<Tag:0x00007f6170641fd0> #<Tag:0x00007f6170641cb0>
Hello everyone,
I was trying to install influxDB + grafana, but had an issue that I couldn’t understand, first of all i used the installation from sudo openhabian-config , InfluxDB is installed but Grafana fails.
I tried to install it on my own using thecommand: sudo apt-get install grafana so I got these lines :
Preparing to unpack …/grafana_5.1.4_armhf.deb …
Unpacking grafana (5.1.4) over (2.6.0+dfsg-3+b1) …
dpkg: error processing archive /var/cache/apt/archives/grafana_5.1.4_armhf.deb ( --unpack):
trying to overwrite ‘/usr/share/grafana/conf/defaults.ini’, which is also in pa ckage grafana-data 2.6.0+dfsg-3
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Errors were encountered while processing:
Updating FireMotD available updates count …
E: Sub-process /usr/bin/dpkg returned an error code (1)
I think here there is problem with FireModT, I upgraded it using sudo apt-get install --upgrade FireMotD here i find another issue:
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package FireMotD
I would be so grateful if anyone had the same issue and found out how to resolve it And thanks :wink:
I’m having the same issue here… any help would be appreciated…
Unlikely, the OP is 2 years old.
If you want people to help, provide data they can act upon.
How to ask a good question / Help Us Help You - Tutorials & Examples - openHAB Community
Hello, my system is:
###############  openhab  #####################################
##        Ip = 192.168.15.20
##   Release = Raspbian GNU/Linux 10 (buster)
##    Kernel = Linux 4.19.97-v7+
##  Platform = Raspberry Pi 3 Model B Rev 1.2
##    Uptime = 1 day(s). 10:53:44
## CPU Usage = 1.01% avg over 4 cpu(s) (4 core(s) x 1 socket(s))
##  CPU Load = 1m: 0.00, 5m: 0.01, 15m: 0.00
##    Memory = Free: 0.08GB (9%), Used: 0.86GB (91%), Total: 0.95GB
##      Swap = Free: 0.67GB (99%), Used: 0.00GB (1%), Total: 0.68GB
##      Root = Free: 108.43GB (96%), Used: 3.79GB (4%), Total: 117.01GB
##   Updates = 1 apt updates available.
##  Sessions = 1 session(s)
## Processes = 118 running processes of 32768 maximum processes
I tried to install Grafana/Influx using openhabian-config, but some errors appeared, now I always have this apt update, when I try to upgrade it, the following errors appears, and the upgrade doesn’t work:
The following packages will be upgraded:
  grafana
1 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Need to get 0 B/41.7 MB of archives.
After this operation, 108 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Reading changelogs... Done
(Reading database ... 68430 files and directories currently installed.)
Preparing to unpack .../grafana_7.0.1_armhf.deb ...
Unpacking grafana (7.0.1) over (2.6.0+dfsg-3+b1) ...
/var/cache/apt/archives/grafana_7.0.1_armhf.deb (--unpack):
 trying to overwrite '/usr/share/grafana/public/test/mocks/dashboard-mock.js', which is also in package grafana-data 2.6.0+dfsg-3
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Updating FireMotD available updates count ...
any help will be appreciated!
Paulo
Looks similar to the issue solved here. Maybe you can try to remove the old Grafana version first?
I tried to follow the post above, used the command sudo apt-get purge grafana-data and it didn´t work:
The following packages were automatically installed and are no longer required:
adwaita-icon-theme at-spi2-core dconf-gsettings-backend dconf-service fonts-font-awesome geoclue-2.0 glib-networking glib-networking-common glib-networking-services
golang-1.11-go golang-1.11-src golang-go golang-src gsettings-desktop-schemas gstreamer1.0-plugins-base gtk-update-icon-cache hicolor-icon-theme iio-sensor-proxy
libatk-bridge2.0-0 libatk1.0-0 libatk1.0-data libatspi2.0-0 libavahi-glib1 libbrotli1 libcairo-gobject2 libcairo2 libcdparanoia0 libcolord2 libcroco3 libdatrie1
libdconf1 libdouble-conversion1 libdrm-amdgpu1 libdrm-common libdrm-nouveau2 libdrm-radeon1 libdrm2 libegl-mesa0 libegl1 libepoxy0 libevdev2 libgbm1
libgdk-pixbuf2.0-0 libgdk-pixbuf2.0-bin libgdk-pixbuf2.0-common libgl1 libgl1-mesa-dri libglapi-mesa libgles2 libgles2-mesa libglvnd0 libglx-mesa0 libglx0
libgraphite2-3 libgstreamer-plugins-base1.0-0 libgtk-3-0 libgtk-3-bin libgtk-3-common libgudev-1.0-0 libharfbuzz0b libhyphen0 libice6 libinput-bin libinput10
libjbig0 libjs-angularjs libjs-jquery-metadata libjs-jquery-tablesorter libjs-twitter-bootstrap libjson-glib-1.0-0 libjson-glib-1.0-common liblcms2-2 libllvm9
libmbim-glib4 libmbim-proxy libmm-glib0 libmtdev1 libnotify4 libogg0 libopus0 liborc-0.4-0 libpango-1.0-0 libpangocairo-1.0-0 libpangoft2-1.0-0 libpcre2-16-0
libpixman-1-0 libproxy1v5 libqmi-glib5 libqmi-proxy libqt5core5a libqt5dbus5 libqt5gui5 libqt5network5 libqt5positioning5 libqt5printsupport5 libqt5qml5
libqt5quick5 libqt5sensors5 libqt5svg5 libqt5webchannel5 libqt5webkit5 libqt5widgets5 librest-0.7-0 librsvg2-2 librsvg2-common libsm6 libsoup-gnome2.4-1
libsoup2.4-1 libthai-data libthai0 libtheora0 libtiff5 libvisual-0.4-0 libvorbis0a libvorbisenc2 libwacom-bin libwacom-common libwacom2 libwayland-client0
libwayland-cursor0 libwayland-egl1 libwayland-server0 libwebp6 libwoff1 libx11-xcb1 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-icccm4 libxcb-image0
libxcb-keysyms1 libxcb-present0 libxcb-randr0 libxcb-render-util0 libxcb-render0 libxcb-shape0 libxcb-shm0 libxcb-sync1 libxcb-util0 libxcb-xfixes0 libxcb-xinerama0
libxcb-xkb1 libxcomposite1 libxcursor1 libxdamage1 libxfixes3 libxi6 libxinerama1 libxkbcommon-x11-0 libxkbcommon0 libxrandr2 libxrender1 libxshmfence1 libxslt1.1
libxtst6 libxxf86vm1 modemmanager notification-daemon phantomjs qt5-gtk-platformtheme qttranslations5-l10n x11-common
Use ‘sudo apt autoremove’ to remove them.
The following additional packages will be installed:
grafana
The following packages will be REMOVED:
grafana-data*
grafana
1 upgraded, 0 newly installed, 1 to remove and 4 not upgraded.
After this operation, 101 MB of additional disk space will be used.
Reading changelogs… Done
(Reading database … 68430 files and directories currently installed.)
Preparing to unpack …/grafana_7.0.1_armhf.deb …
Unpacking grafana (7.0.1) over (2.6.0+dfsg-3+b1) …
dpkg: error processing archive /var/cache/apt/archives/grafana_7.0.1_armhf.deb (–unpack):
trying to overwrite ‘/usr/share/grafana/public/test/mocks/dashboard-mock.js’, which is also in package grafana-data 2.6.0+dfsg-3
