The persistence for InfluxDB does impose some limitations: you can’t use the tags and the multiple values and different retention policies in InfluxDB. For example, you could have a measurement “Temperature” and the tags “Inside” and “Outside”. Or maybe you want some measurements saved forever and others for much less time. You can use continuous queries to down sample, but it doesn’t cover every case. Also, you can have a measurement “SensorValues” with values such as Temperature and Humidity all within that measurement. Fortunately there is quite an easy workaround with the HTTP post request. I’ve put a sample below for anyone who is interested. If you’ve used the authentication above, you’ll need to add it to the http val. And of course modify it to your liking.
I want to implement a “Direct Link Rendered Image” into my Habpanel.
Problem is, that the background is black from the dark theme or white from the light theme.
In the thread of the matrix theme I saw that it should be possible to create a css file, which I have to implement into the index.html file under directly below the title tag.
I did this, but without success.
In Installed influxdb and grafana according to the describtion above, version 1.0.2. was installed (using an Pi 3+).
But i cannot go to the command line interface?
When I run influx, the answer is command not found.
I can start somethin running influxd. Then i get this:
[run] 2019/02/10 14:59:29 InfluxDB starting, version 1.0.2, branch unknown, commit unknown
[run] 2019/02/10 14:59:29 Go version go1.7.3, GOMAXPROCS set to 4
[run] 2019/02/10 14:59:30 Using configuration at: /etc/influxdb/influxdb.conf
run: open server: listen: listen tcp :8088: bind: address already in use
influxd is the daemon (and already started… bind: address already in use)
if there is an influxd, there also should be an influx (which is the connection to the database command line)
I would try this. I recently installed influxdb and got only the server and not the client on Ubuntu 18.04 server. Perhaps they have separated the server and the client in the latest package.
finding the influx command was what hung me up trying to do this tutorial. Eventually I found info telling me to point my web browser at the web interface which can be found at
localhost:8083
after install
the web interface allows the creation of databases, users and permissions
hope it helps
Port 8083 for admin can work, but you need to enable it first in the influxdb.conf file in the admin section as the default is disabled. Also, it says that the interface is deprecated and will be removed in a future release.
Hope this is the correct location for my two questions …
I measure few temperatures, store the values every 5 minutes in an influxdb.
Now, the graph for 1 day (or less) view has “steps” because of less values.
But is there an option that Grafana interpolate (create a curve betwen the point) and the graph looks “smoother” ?
(Otherwise I have to save every minute the temperatues into the influxdb …)
And in Grafana under “Legend” I activate “Show” and “As table”:
But this will only show (the first) three temperature sensores I added (in the graph there are six shown, thats correct). See picture
When activating additionally “To the right”, than all six values are shown on the right part from the screen (but than the graph is to much shrinked). Is this a limitation, a Bug or a mistake on my side?
OK, for my second question I found out:
When moving over on the right part, a scroll line appear!
Without move-over there is NO hint that there are more lines!
Hello All, i’m in need of a tiny bit of help…
I’m sure the issue will be obvious to someone, i can’t seem to put my finger on it.
I confess i ventured into installing InfluxDB and Grafana from the openhabian-config>optional components installation ( i thought: “it’s been 2 years ever since Thomas Dietrich wrote this tutorial, let’s be brave!” - btw the tutorial is definitely still relevant, so TY).
The automated setup process sets up most of the things for you, basically all there is left is to install the addon in paperui and schedule a persistence job.
I now have the follwoing situation:
Grafana says it has no issues in connecting to opehab_db from influx as datasource
Influx receives data from OH, as per the scheduled job, (with precision rfc3339)
i don’t get any result, except for a “no data points” written in the middle of the graph.
I’m sure i missed something silly (as usual for any first timer the amount of info can be overwhelming).
any pointers?
Thanks!!
EDIT: do i need to write SELECT * FROM … so influxdb CLI commands in the grafana query for it to work??
EDIT 2: i’ve tried logging into influx’s CLI with grafana’s credentials and reading the measurements, but got this error:
EDIT for anybody who might face the same issue
if you install Grafana and InfluxDB from the automated procedure in the openhabian-config, you need to log into influx’s CLI as ‘admin’ with the ‘SuperSecretPassword123+’ you’ve set up during the process, and do the 2 GRANT commands above. otherwise it’s not going ot work XD
Hi there!
How can i update Grafana? I’m on 5.1.4 - according to the grafana homepage there’s 6.0 available.
i’m trying to update because (maybe?) 6.0 solves my problem with scrollbars on habpanel
does anyone have an idea why transparency doesn’t work, if a graph is used in HABpanel using an iframe? I don’t think that it is an issue of grafana since transparency works without problems, if the frame is opened directly. Is there any additional HABpanel or CSS setting necessary to make this work in HABpanel?
I write here because after searching and searching I have not found a solution to my problem. I followed the whole tutorial and I was able to install influxdb and grafana perfectly, I even have several graphs working on my sitemap with influxdb. My problem comes with grafana. I could only enter when I installed it and after that I could not do it anymore. I have reinstalled it several times without success. It appears in my openhab web panel but when I click it it does not connect me. The truth is that I have searched and tried many things before writing here. In the log I do not see any error regarding grafana. I do not know what else to do. It may be silly and I do not see it but I have run out of ideas.
My setup is:
Hardware: Raspberry PI 3B
OS: openHABian v1.4.1
Java Runtime Environment: openjdk version “1.8.0_152”
OpenJDK Runtime Environment (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 1.8 .0_152-b76)
OpenJDK Client VM (Zulu Embedded 8.25.0.76-linux-aarch32hf) (build 25.152-b76, m ixed mode, Evaluation)
