I managed to get it working with Grafana 8, with only small changes to the library from @wborn
Here is, what I changed in the library (the version from the /web-src/ directory of the Github repository):
Changed the paths in function OHG_DEFAULTS():
panelPath: "/d/"
renderPanelPath: "/d/"
Renamed the ‘panelId’ in function GrafanaPanel()
key: "viewPanel"
Added the kiosk mode to the URL in function updateFrameSourceURL()
After the loop for (var uvKey in urlVars):
url += "&" + "kiosk=1";
As reference I added my version of the library below
In the sitemap only the dashboard parameter has to be changed, either to only the uid or to uid/name of the dashboard, e.g.:
Webview url="/static/grafana/grafana.html?dashboard=000000009&from=now-48h&to=now&panel=4" height=12
You can find the uid e.g. when viewing the dashboard as json in the export menu.
As I know nothing about Javascript or Html, this probably is not the best way to change the library and it will most probably not work in all use cases, but my wife is happy again Maybe it is a starting point for someone who actually knows what he does.
Here the full library. I also defined the urlPrefix, according to my installation, in the library, probably this is not needed when correctly defined in the user configuration file
* openHAB Grafana panel utilities
* Updates the source URL of Grafana <iframe> panels using openHAB server side events (SSE).
* OHSubscriber is based on the javascript of the openHAB Basic UI by Vlad Ivanov.
* @author Wouter Born
/* exported addGrafanaPanel, GrafanaPanel */
/* eslint-env browser */
/* eslint no-undef:2 */
/* eslint no-new:0 */
/* eslint no-underscore-dangle:0 */
"use strict";
var
OHG_DEFAULTS = {
// library
debug: "false",
render: "false",
refresh: "0",
// OH sitemap
sitemap: "default",
// Grafana URL
urlPrefix: "http://server.domain.internal:9080/grafana",
panelPath: "/d/",
renderPanelPath: "/d/",
// Grafana panel parameters
to: "now",
theme: "light",
// Grafana render panel parameters
width: "auto",
height: "auto"
function queryParams(param) {
if (!param) {
return {};
var
match,
url = param.toString(),
queryIndex = url.indexOf("?"),
query = queryIndex !== -1 ? url.substring(queryIndex + 1) : "",
re = /([^&=]+)=?([^&]*)/g,
decode = function (s) { return decodeURIComponent(s.replace(/\+/g, " ")); },
result = {};
do {
match = re.exec(query);
if (match) {
result[decode(match[1])] = decode(match[2]);
} while (match);
return result;
var
urlParams = queryParams(window.location),
parentUrlParams = queryParams(window.parent.location.href);
function resolveParam(params, name) {
if (params !== undefined && params[name] !== undefined) {
return params[name];
} else if (urlParams !== undefined && urlParams[name] !== undefined) {
return urlParams[name];
} else if (parentUrlParams !== undefined && parentUrlParams[name] !== undefined) {
return parentUrlParams[name];
} else {
return OHG_DEFAULTS[name];
function OHSubscriber(params) {
var
p = params,
initialized = false,
initializedListeners = [],
items = {},
subscription = {
page: resolveParam(p, "w"),
sitemap: resolveParam(p, "sitemap")
this.addItemListener = function(itemName, listener) {
if (typeof listener !== "function") {
throw new Error("addItemListener 'listener' is not a function");
if (items[itemName] !== undefined) {
if (!items[itemName].listeners.includes(listener)) {
items[itemName].listeners.push(listener);
} else {
items[itemName] = {listeners: [listener], value: undefined};
this.addInitializedListener = function(listener) {
throw new Error("addInitializedListener 'listener' is not a function");
initializedListeners.push(listener);
this.isInitialized = function() {
return initialized;
function ajax(params) {
var
p = params,
type = typeof p.type !== "undefined" ? p.type : "GET",
data = typeof p.data !== "undefined" ? p.data : "",
headers = typeof p.headers !== "undefined" ? p.headers : {},
request = new XMLHttpRequest();
request.open(type, p.url, true);
for (var h in headers) {
request.setRequestHeader(h, headers[h]);
request.onload = function() {
if (request.status < 200 || request.status > 400) {
if (typeof p.error === "function") {
p.error(request);
return;
if (typeof p.callback === "function") {
p.callback(request);
request.onerror = function() {
p.error(request);
request.send(data);
return request;
function uninitializedItemNames() {
var result = [];
for (var itemName in items) {
if (items[itemName].value === undefined) {
result.push(itemName);
return result;
function areAllItemsInitialized() {
return uninitializedItemNames().length === 0;
function updateInitialized() {
if (!initialized && areAllItemsInitialized()) {
initialized = true;
for (var i = 0; i < initializedListeners.length; i++) {
initializedListeners[i]();
function updateItem(itemName, value) {
if (items[itemName].value === value) {
return;
items[itemName].value = value;
var itemListeners = items[itemName].listeners;
for (var i = 0; i < itemListeners.length; i++) {
var listener = itemListeners[i];
listener(itemName, value);
updateInitialized();
function ChangeListenerEventsource(subscribeLocation) {
var
_t = this;
_t.navigate = function(){};
_t.source = new EventSource(subscribeLocation);
_t.source.addEventListener("event", function(payload) {
if (_t.paused) {
return;
var
data = JSON.parse(payload.data),
itemName = data.item.name,
value;
if (items[itemName] === undefined) {
return;
if (
(typeof(data.label) === "string") &&
(data.label.indexOf("[") !== -1) &&
(data.label.indexOf("]") !== -1)
var
pos = data.label.indexOf("[");
value = data.label.substr(
pos + 1,
data.label.lastIndexOf("]") - (pos + 1)
} else {
value = data.item.state;
updateItem(itemName, value);
function ChangeListenerLongpolling() {
var
_t = this;
function applyChanges(response) {
try {
response = JSON.parse(response);
} catch (e) {
return;
function walkWidgets(widgets) {
widgets.forEach(function(widget) {
if (widget.item === undefined) {
return;
var
itemName = widget.item.name,
value = widget.item.state;
if (response.leaf) {
walkWidgets(response.widgets);
} else {
response.widgets.forEach(function(frameWidget) {
walkWidgets(frameWidget.widgets);
function start() {
var
cacheSupression = Math.random().toString(16).slice(2);
_t.request = ajax({
url: "/rest/sitemaps/" + subscription.sitemap + "/" + subscription.page + "?_=" + cacheSupression,
headers: {"X-Atmosphere-Transport": "long-polling"},
callback: function(request) {
applyChanges(request.responseText);
setTimeout(function() {
start();
}, 1);
error: function() {
// Wait 1s and restart long-polling
start();
}, 1000);
start();
function ChangeListener() {
var
_t = this;
_t.startSubscriber = function(response) {
var
responseJSON,
subscribeLocation,
subscribeLocationArray;
try {
responseJSON = JSON.parse(response.responseText);
} catch (e) {
return;
if (responseJSON.status !== "CREATED") {
return;
try {
subscribeLocation = responseJSON.context.headers.Location[0];
} catch (e) {
return;
subscribeLocationArray = subscribeLocation.split("/");
subscription.id = subscribeLocationArray[subscribeLocationArray.length - 1];
if ("EventSource" in window) {
ChangeListenerEventsource.call(_t, subscribeLocation +
"?sitemap=" + subscription.sitemap +
"&pageid=" + subscription.page);
} else {
ChangeListenerLongpolling.call(_t);
ajax({
url: "/rest/sitemaps/events/subscribe",
type: "POST",
callback: _t.startSubscriber
function ValuesInitializer() {
var
_t = this;
_t.valueHandler = function(response) {
var
responseJSON;
try {
} catch (e) {
return;
updateItem(responseJSON.name, responseJSON.state);
var itemNames = uninitializedItemNames();
for (var i = 0; i < itemNames.length; i++) {
ajax({
url: "/rest/items/" + itemNames[i],
type: "GET",
callback: _t.valueHandler
function initialize() {
if (subscription.page === undefined) {
subscription.page = subscription.sitemap;
document.addEventListener("DOMContentLoaded", function() {
subscription.valuesInitializer = new ValuesInitializer();
subscription.changeListener = new ChangeListener();
initialize();
var ohSubscriber = new OHSubscriber();
function GrafanaPanel(params) {
var
p = params,
refreshTimerId = undefined,
resizeTimerId = undefined,
frame = resolveParam(p, "frame"),
urlPrefix = resolveParam(p, "urlPrefix"),
panelPath = resolveParam(p, "panelPath"),
renderPanelPath = resolveParam(p, "renderPanelPath"),
libVars = {
debug: {
value: resolveParam(p, "debug"),
itemName: resolveParam(p, "debugItem"),
itemFunction: params.debugItemFunction
render: {
value: resolveParam(p, "render"),
itemName: resolveParam(p, "renderItem"),
itemFunction: params.renderItemFunction
refresh: {
value: resolveParam(p, "refresh"),
itemName: resolveParam(p, "refreshItem"),
itemFunction: params.refreshItemFunction
urlVars = {
dashboard: {
value: resolveParam(p, "dashboard"),
itemName: resolveParam(p, "dashboardItem"),
itemFunction: params.dashboardItemFunction
key: "from",
value: resolveParam(p, "from"),
itemName: resolveParam(p, "fromItem"),
itemFunction: params.fromItemFunction
to: {
key: "to",
value: resolveParam(p, "to"),
itemName: resolveParam(p, "toItem"),
itemFunction: params.toItemFunction
panel: {
key: "viewPanel",
value: resolveParam(p, "panel"),
itemName: resolveParam(p, "panelItem"),
itemFunction: params.panelItemFunction
theme: {
key: "theme",
value: resolveParam(p, "theme"),
itemName: resolveParam(p, "themeItem"),
itemFunction: params.themeItemFunction
width: {
key: "width",
value: resolveParam(p, "width"),
itemName: resolveParam(p, "widthItem"),
itemFunction: params.widthItemFunction
height: {
key: "height",
value: resolveParam(p, "height"),
itemName: resolveParam(p, "heightItem"),
itemFunction: params.heightItemFunction
function updateFrameSourceURL() {
var debug = libVars.debug.value;
var render = libVars.render.value;
var refresh = libVars.refresh.value;
var iframe = document.getElementById(frame);
var idocument = iframe.contentWindow.document;
var url = urlPrefix;
url += render === "true" ? renderPanelPath : panelPath;
url += urlVars.dashboard.value;
var firstParameter = true;
for (var uvKey in urlVars) {
var key = urlVars[uvKey].key;
var value = urlVars[uvKey].value;
if (key === "width") {
value = render === "false" ? undefined : (value === "auto" ? idocument.body.clientWidth : value);
} else if (key === "height") {
value = render === "false" ? undefined : (value === "auto" ? idocument.body.clientHeight : value);
if (key !== undefined && value !== undefined) {
url += (firstParameter ? "?" : "&") + key + "=" + value;
firstParameter = false;
if (render === "true") {
// append cache busting parameter
url += "&cacheBuster=" + Date.now();
// update frame content
if (debug === "true") {
idocument.open();
idocument.write("<a href=\"" + url + "\">" + url + "</a>");
idocument.close();
} else if (render === "true") {
var htmlUrl = url.replace(renderPanelPath, panelPath);
idocument.open();
idocument.write("<style>body{margin:0px}p{margin:0px}</style>");
idocument.write("<p style=\"text-align:center;\"><a href=\"" + htmlUrl + "\"><img src=\"" + url + "\"></a></p>");
idocument.close();
} else if (document.getElementById(frame).src !== url) {
// replace the URL so changes are not added to the browser history
iframe.contentWindow.location.replace(url);
// schedule/cancel rendered image refresh
if (render === "true" && refresh > 0) {
clearTimeout(refreshTimerId);
refreshTimerId = setTimeout(updateFrameSourceURL, refresh);
} else if (refreshTimerId !== undefined) {
function updateFrameOnResize() {
if (libVars.render.value === "true" && (urlVars.width.value === "auto" || urlVars.height.value === "auto")) {
clearTimeout(resizeTimerId);
resizeTimerId = setTimeout(updateFrameSourceURL, 500);
} else {
function updateVarsOnItemUpdate(vars, itemName, value) {
for (var key in vars) {
if (vars[key].itemName !== undefined && vars[key].itemName === itemName) {
if (vars[key].itemFunction) {
value = vars[key].itemFunction(value);
vars[key].value = value;
function onItemUpdated(itemName, value) {
updateVarsOnItemUpdate(libVars, itemName, value);
updateVarsOnItemUpdate(urlVars, itemName, value);
if (ohSubscriber.isInitialized()) {
updateFrameSourceURL();
function assertPropertyDefined(name, value) {
if (value === undefined) {
throw new Error("Property '" + name + "' is undefined");
function assertVarsDefinedOrSubscribeToOH(vars) {
var itemName = vars[key].itemName;
if (itemName !== undefined) {
ohSubscriber.addItemListener(itemName, onItemUpdated);
} else if (vars[key].value === undefined) {
throw new Error("Property '" + key + "' requires a default value or itemName to obtain the value from");
assertPropertyDefined("frame", frame);
assertPropertyDefined("urlPrefix", urlPrefix);
assertPropertyDefined("panelPath", panelPath);
assertPropertyDefined("renderPanelPath", renderPanelPath);
assertVarsDefinedOrSubscribeToOH(libVars);
assertVarsDefinedOrSubscribeToOH(urlVars);
ohSubscriber.addInitializedListener(updateFrameSourceURL);
window.addEventListener("resize", updateFrameOnResize);
initialize();
var grafanaPanels = [];
function createGuid()
return "xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx".replace(/[xy]/g, function(c) {
var r = Math.random()*16|0, v = c === "x" ? r : (r&0x3|0x8);
return v.toString(16);
function addGrafanaPanel(uniqueId, params) {
if (uniqueId === undefined) {
uniqueId = createGuid();
var div = document.createElement("div");
div.id = "panel-" + uniqueId + "-container";
div.className = "panel-container";
document.body.appendChild(div);
var frame = document.createElement("iframe");
frame.id = "panel-" + uniqueId + "-frame";
frame.className = "panel-frame";
frame.scrolling = "no";
div.appendChild(frame);
if (params === undefined) {
params = {};
params.frame = frame.id;
var panel = new GrafanaPanel(params);
grafanaPanels.push(panel);
