I just realized after having ran “reinstall” for grafana, that it seems I’m still with version 5.1.4… I’m on a standard openhabian install, I’m not sure why the apt-get update & upgrade did not upgrade grafana?
Also, when I look at the reporsitory file for grafana, this is what I see… Not sure it is normal?
> [12:14:38] openhabian@openHABianPi:~$ more /etc/apt/sources.list.d/gra*
> deb https://dl.bintray.com/fg2it/deb jessie main
> [12:15:10] openhabian@openHABianPi:~$
Ok, I followed this info and ran apt-get upgrade, it installed grafana 6.2 and all seems ok, I have again access to my Grafana dashboards… Not exactly sure of why and how I got there, but all seems ok now.
Well I silently read (and learned) tons of stuff here in the openhab community forums.
Now I am at a point where I need help (and actually feel pretty dumb):
I followed @pahansen Tutorial on 'webview element" for implementing my grafana output rather than letting my RPi render images (which takes very long and sometimes they do not refresh in the app).
I have the chartshour, -day and week.html as well as the charts.css in my conf/html folder.
I added the suggested part in my sitemap-file and changed filepaths from relative to absolute.
The logs give me the following output after updating my sitemap:
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'Charts' for widget org.eclipse.smarthome.model.sitemap.Text
[WARN ] [basic.internal.render.SwitchRenderer] - Cannot determine item type of 'weatherChartPeriod'
org.eclipse.smarthome.core.items.ItemNotFoundException: Item 'weatherChartPeriod' could not be found in the item registry
{loads of java error, removed for better readability}
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'weatherChartPeriod' for widget org.eclipse.smarthome.model.sitemap.Switch
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
[ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item weatherChartPeriod for widget org.eclipse.smarthome.model.sitemap.Webview
Ok, so the net::ERR_BLOCKED_BY_RESPONSE could be solved with uncommenting “allow_embedding=true” in grafana.ini and restarting grafana-server (sudo systemctl restart grafana-server)
Somehow I still can’t get the switch to work (I don’t need it but I am curious about what the heck I am missing)
Querying the database directly with curl -G 'http://localhost:8086/query?pretty=true' --data-urlencode "db=mydb" --data-urlencode "q=SELECT * FROM \"cpu_load_short\"
otherwise using the cli is even faster. If you don’t see any response or the there are not the values that you expect, then you know that it’s not being recorded
Would be great if this new info could be added to the tutorial.Would save some frustrating hours especially for first time grafana users wondering why charts are not showing.Other than that the tutorial is perfect.
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
allow_embedding = true
