And show databases yields:
> show databases
name
> show databases
name
Perfect.
That means there is no user at all defined in influxdb ( the list below the headline is empty ).
And there is also no database defined yet ( besides the headline nothing is being shown ).
This means create the database and the admin and the grafana user first.
Commands are described in very first post of this thread.
This also could/should be done by running the openhabian install procedure for influxdb.
As there is no influxdb right now you also cannot already have data collected yet - at least not in influxdb.
Hmm, I started openhabian-config and executed the installation of influx&grafana again. It failed. I tried it 3 times. I started openhabian-config once from the root and once from ./home/openhabian
InfluxDB installation seemed to work, but not Grafana.
openhabian@openhabian:~ $ openhabian-config
2022-01-07_15:39:18_CET [openHABian] Checking for root privileges...
This script must be run as root. Did you mean 'sudo openhabian-config'?
More info: https://www.openhab.org/docs/installation/openhabian.html
openhabian@openhabian:~ $ sudo openhabian-config
[sudo] password for openhabian:
2022-01-07_15:39:28_CET [openHABian] Checking for root privileges... OK
2022-01-07_15:39:28_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2022-01-07_15:39:28_CET [openHABian] openHABian configuration tool version: [openHAB3]{2021-12-02T09:19:37-07:00}(bb960d8)
2022-01-07_15:39:28_CET [openHABian] Checking for changes in origin branch openHAB3... OK
2022-01-07_15:39:30_CET [openHABian] Switching to branch openHAB3... OK
2022-01-07_15:39:30_CET [openHABian] Adding slightly tuned bash configuration files to system... OK
2022-01-07_15:39:37_CET [openHABian] Updating Linux package information... OK
2022-01-07_15:39:38_CET [openHABian] Beginning setup of InfluxDB and Grafana... OK
2022-01-07_15:39:39_CET [openHABian] Configuring InfluxDB... OK
2022-01-07_15:42:28_CET [openHABian] Configuring Grafana... OK
2022-01-07_15:43:32_CET [openHABian] Installing InfluxDB... OK
2022-01-07_15:43:35_CET [openHABian] Setting up new InfluxDB installation... OK
2022-01-07_15:43:36_CET [openHABian] Installing Grafana.. FAILED
2022-01-07_15:45:02_CET [openHABian] Updating Linux package information... OK
2022-01-07_15:45:02_CET [openHABian] Beginning setup of InfluxDB and Grafana... OK
2022-01-07_15:45:03_CET [openHABian] Configuring InfluxDB... OK
2022-01-07_15:46:23_CET [openHABian] Configuring Grafana... OK
2022-01-07_15:46:39_CET [openHABian] Setting up new InfluxDB installation... OK
2022-01-07_15:46:40_CET [openHABian] Installing Grafana.. FAILED
2022-01-07_15:48:16_CET [openHABian] Checking for default openHABian username:password combination... OK
2022-01-07_15:48:16_CET [openHABian] We hope you got what you came for! See you again soon ;)
openhabian@openhabian:~ $ pwd
/home/openhabian
openhabian@openhabian:~ $ cd..
openhabian@openhabian:/home $ cd..
openhabian@openhabian:/ $ sudo openhabian-config
2022-01-07_15:48:37_CET [openHABian] Checking for root privileges... OK
2022-01-07_15:48:38_CET [openHABian] Loading configuration file '/etc/openhabian.conf'... OK
2022-01-07_15:48:38_CET [openHABian] openHABian configuration tool version: [openHAB3]{2021-12-02T09:19:37-07:00}(bb960d8)
2022-01-07_15:48:38_CET [openHABian] Checking for changes in origin branch openHAB3... OK
2022-01-07_15:48:40_CET [openHABian] Switching to branch openHAB3... OK
2022-01-07_15:48:40_CET [openHABian] Adding slightly tuned bash configuration files to system... OK
2022-01-07_15:48:47_CET [openHABian] Updating Linux package information... OK
2022-01-07_15:48:47_CET [openHABian] Beginning setup of InfluxDB and Grafana... OK
2022-01-07_15:48:48_CET [openHABian] Configuring InfluxDB... OK
2022-01-07_15:50:09_CET [openHABian] Configuring Grafana... OK
2022-01-07_15:50:17_CET [openHABian] Installing InfluxDB... OK
2022-01-07_15:50:20_CET [openHABian] Setting up new InfluxDB installation... OK
2022-01-07_15:50:21_CET [openHABian] Installing Grafana.. FAILED
2022-01-07_15:52:15_CET [openHABian] Checking for default openHABian username:password combination... OK
2022-01-07_15:52:15_CET [openHABian] We hope you got what you came for! See you again soon ;)
I used my own (and 3 different usernames) when being asked to enter the various usernames.
I ran the installation in maximum debug mode: influx seemingly was successfully installed. but on Grafana an access to localhost:3000 is refusedā¦???
curl: (7) Failed to connect to localhost port 3000: Connection refused
The last part of the debugging info:
Check if InfluxDB is running...
+ cond_redirect curl --retry 6 --retry-connrefused --user myNameAdmin:12345678 --insecure http://localhost:8086/query
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --retry 6 --retry-connrefused --user myNameAdmin:12345678 --insecure http://localhost:8086/query \033[39;49;00m'
+ curl --retry 6 --retry-connrefused --user myNameAdmin:12345678 --insecure http://localhost:8086/query
{"error":"missing required parameter \"q\""}
+ return 0
+ echo OK
OK
+ return 0
+ echo OK
OK
+ influxDBAddress=http://localhost:8086
+ [[ -n myNameAdmin ]]
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-07_16:17:49_CET [openHABian] Setting up new InfluxDB installation... '
2022-01-07_16:17:49_CET [openHABian] Setting up new InfluxDB installation... + cond_echo 'Creating InfluxDB database myNameOH'
+ [[ -z '' ]]
+ echo -e '\033[33;01mCreating InfluxDB database myNameOH\033[39;49;00m'
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE DATABASE myNameOH'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=CREATE DATABASE myNameOH \033[39;49;00m'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE DATABASE myNameOH'
{"results":[{"statement_id":0}]}
+ return 0
+ cond_echo 'Creating InfluxDB user myNameOpenhab'
+ [[ -z '' ]]
+ echo -e '\033[33;01mCreating InfluxDB user myNameOpenhab\033[39;49;00m'
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE USER myNameOpenhab WITH PASSWORD '\''12345678'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=CREATE USER myNameOpenhab WITH PASSWORD '\''12345678'\'' \033[39;49;00m'
$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=CREATE USER myNameOpenhab WITH PASSWORD '12345678'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE USER myNameOpenhab WITH PASSWORD '\''12345678'\'''
+ return 0
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=SET PASSWORD FOR myNameOpenhab = '\''12345678'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=SET PASSWORD FOR myNameOpenhab = '\''12345678'\'' \033[39;49;00m'
$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=SET PASSWORD FOR myNameOpenhab = '12345678'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=SET PASSWORD FOR myNameOpenhab = '\''12345678'\'''
+ return 0
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=GRANT ALL ON myNameOH TO myNameOpenhab'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=GRANT ALL ON myNameOH TO myNameOpenhab \033[39;49;00m'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=GRANT ALL ON myNameOH TO myNameOpenhab'
+ return 0
+ cond_echo 'Creating InfluxDB user myNameGrafana2influx'
+ [[ -z '' ]]
+ echo -e '\033[33;01mCreating InfluxDB user myNameGrafana2influx\033[39;49;00m'
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE USER myNameGrafana2influx WITH PASSWORD '\''12345678'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=CREATE USER myNameGrafana2influx WITH PASSWORD '\''12345678'\'' \033[39;49;00m'
$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=CREATE USER myNameGrafana2influx WITH PASSWORD '12345678'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=CREATE USER myNameGrafana2influx WITH PASSWORD '\''12345678'\'''
+ return 0
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=SET PASSWORD FOR myNameGrafana2influx = '\''12345678'\'''
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=SET PASSWORD FOR myNameGrafana2influx = '\''12345678'\'' \033[39;49;00m'
$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=SET PASSWORD FOR myNameGrafana2influx = '12345678'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=SET PASSWORD FOR myNameGrafana2influx = '\''12345678'\'''
+ return 0
+ cond_redirect curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=GRANT READ ON myNameOH TO myNameGrafana2influx'
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode q=GRANT READ ON myNameOH TO myNameGrafana2influx \033[39;49;00m'
+ curl --user myNameAdmin:12345678 --insecure http://localhost:8086/query --data-urlencode 'q=GRANT READ ON myNameOH TO myNameGrafana2influx'
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-07_16:17:50_CET [openHABian] Installing Grafana.. '
2022-01-07_16:17:50_CET [openHABian] Installing Grafana.. + cond_redirect grafana_install 12345678
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ grafana_install 12345678 \033[39;49;00m'
+ grafana_install 12345678
+ local adminPassword=12345678
+ local keyName=grafana
+ grafana_is_installed
+ dpkg -s grafana
+ [[ -s /etc/grafana/grafana.ini ]]
+ return 0
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-07_16:17:50_CET [openHABian] Setting up Grafana service... '
2022-01-07_16:17:50_CET [openHABian] Setting up Grafana service... + cond_redirect zram_dependency install grafana-server
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ zram_dependency install grafana-server \033[39;49;00m'
+ zram_dependency install grafana-server
+ local zramServiceConfig=/etc/systemd/system/zram-config.service
+ local install=yes
+ [[ -f /etc/ztab ]]
+ [[ install == \i\n\s\t\a\l\l ]]
+ shift 1
+ [[ grafana-server == \r\e\m\o\v\e ]]
+ for arg in "$@"
+ [[ yes == \y\e\s ]]
+ grep -qs grafana-server.service /etc/systemd/system/zram-config.service
+ [[ yes == \n\o ]]
+ cond_redirect systemctl -q daemon-reload
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl -q daemon-reload \033[39;49;00m'
+ systemctl -q daemon-reload
+ return 0
+ return 0
+ zram_is_installed
+ [[ -s /etc/ztab ]]
+ [[ -d /opt/zram ]]
+ return 0
+ mkdir -p /opt/zram/log.bind/grafana /var/log/grafana
+ cond_redirect systemctl enable --now grafana-server.service
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ systemctl enable --now grafana-server.service \033[39;49;00m'
+ systemctl enable --now grafana-server.service
Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
Executing: /lib/systemd/systemd-sysv-install enable grafana-server
+ return 0
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-07_16:17:52_CET [openHABian] Setting up Grafana... '
2022-01-07_16:17:52_CET [openHABian] Setting up Grafana... + cond_echo '\nWait for Grafana to start... '
+ [[ -z '' ]]
+ echo -e '\033[33;01m\nWait for Grafana to start... \033[39;49;00m'
+ cond_redirect curl -4 --retry 6 --retry-connrefused --insecure --head http://localhost:3000
+ [[ -n '' ]]
+ echo -e '\n\033[90;01m$ curl -4 --retry 6 --retry-connrefused --insecure --head http://localhost:3000 \033[39;49;00m'
+ curl -4 --retry 6 --retry-connrefused --insecure --head http://localhost:3000
Warning: Problem : connection refused. Will retry in 1 seconds. 6 retries
Warning: left.
Warning: Problem : connection refused. Will retry in 2 seconds. 5 retries
Warning: left.
Warning: Problem : connection refused. Will retry in 4 seconds. 4 retries
Warning: left.
Warning: Problem : connection refused. Will retry in 8 seconds. 3 retries
Warning: left.
Warning: Problem : connection refused. Will retry in 16 seconds. 2 retries
Warning: left.
Warning: Problem : connection refused. Will retry in 32 seconds. 1 retries
Warning: left.
+ return 7
+ echo 'FAILED (wait for Grafana to start)'
+ return 1
+ return 1
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "20 | Optional Components"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
+ true
+ show_main_menu
+ local choice
+ local version
+++ get_git_revision
+++ local branch
+++ local commitDate
+++ local shorthash
++++ git -C /opt/openhabian rev-parse --abbrev-ref HEAD
+++ branch=openHAB3
++++ git -C /opt/openhabian log --pretty=format:%aI -n 1
+++ commitDate=2021-12-02T09:19:37-07:00
++++ git -C /opt/openhabian log --pretty=format:%h -n 1
+++ shorthash=bb960d8
+++ echo '[openHAB3]{2021-12-02T09:19:37-07:00}(bb960d8)'
++ whiptail --title 'openHABian Configuration Tool ā [openHAB3]{2021-12-02T09:19:37-07:00}(bb960d8)' --menu 'Setup Options' 19 116 12 --cancel-button Exit --ok-button Execute '00 | About openHABian' 'Information about the openHABian project and this tool' '' '' '01 | Select Branch' 'Select the openHABian config tool version ("branch") to run' '02 | Upgrade System' 'Update all installed software packages (incl. openHAB) to their latest version' '03 | Install openHAB' 'Install or upgrade to openHAB 3' '04 | Import config' 'Import an openHAB 3 configuration from file or URL' '' '' '10 | Apply Improvements' 'Apply the latest improvements to the basic openHABian setup āŗ' '20 | Optional Components' 'Choose from a set of optional software components āŗ' '30 | System Settings' 'A range of system and hardware related configuration steps āŗ' '40 | openHAB Related' 'Switch the installed openHAB version or apply tweaks āŗ' '50 | Backup/Restore' 'Manage backups and restore your system āŗ'
+ choice=
+ RET=1
+ '[' 1 -eq 1 ']'
+ return 255
+ system_check_default_password
+ is_pi
+ is_pifour
+ [[ '' == \p\i\4 ]]
+ grep -q '^Revision\s*:\s*[ 123][0-9a-fA-F][0-9a-fA-F][0-9a-fA-F]11[0-9a-fA-F]$' /proc/cpuinfo
+ return 0
+ return 0
+ local algo
+ local defaultPassword
+ local defaultUser
+ local generatedPassword
+ local introText
+ local originalPassword
+ local salt
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ id -u pi
+ is_pi
+ is_pifour
+ return 0
+ return 0
+ defaultUser=openhabian
+ defaultPassword=openhabian
++ grep -w openhabian /etc/shadow
++ cut -d: -f2
+ originalPassword='$y$j9T$WDuhwaGgLhKT5f09ID/5n/$TKRPXY0Z9qeY0CRH8Ez7X72VKuFEV/N/uVXAylXxNID'
++ echo '$y$j9T$WDuhwaGgLhKT5f09ID/5n/$TKRPXY0Z9qeY0CRH8Ez7X72VKuFEV/N/uVXAylXxNID'
++ cut '-d$' -f2
+ algo=y
+ introText='The default password was detected on your system! That is a serious security concern. Bad guys or malicious programs in your subnet are able to gain root access!\n\nPlease set a strong password by typing the command '\''passwd openhabian'\''!'
++ cut '-d$' -f3
+ salt=j9T
+ export algo defaultPassword salt
++ perl -le 'print crypt("$ENV{defaultPassword}","\$$ENV{algo}\$$ENV{salt}\$")'
+ generatedPassword='$y$j9T$$1DJdHt2WNxWqFR3sUxwYKh.KdyI9MF4X/A9710MJGjA'
++ timestamp
++ date +%F_%T_%Z
+ echo -n '2022-01-07_16:19:49_CET [openHABian] Checking for default openHABian username:password combination... '
2022-01-07_16:19:49_CET [openHABian] Checking for default openHABian username:password combination... ++ id -u openhabian
+ [[ -n 1000 ]]
+ [[ $y$j9T$$1DJdHt2WNxWqFR3sUxwYKh.KdyI9MF4X/A9710MJGjA == \$\y\$\j\9\T\$\W\D\u\h\w\a\G\g\L\h\K\T\5\f\0\9\I\D\/\5\n\/\$\T\K\R\P\X\Y\0\Z\9\q\e\Y\0\C\R\H\8\E\z\7\X\7\2\V\K\u\F\E\V\/\N\/\u\V\X\A\y\l\X\x\N\I\D ]]
+ echo OK
OK
++ timestamp
++ date +%F_%T_%Z
+ echo -e '2022-01-07_16:19:49_CET [openHABian] We hope you got what you came for! See you again soon ;)'
Now I found another interesting issue: the config files of influxDB WERE NOT changed with the reinstatement. they hold obsolete information!
openhab
is NOT the username I used in the installation process, but myNameAdmin
ā¦
that means to me that there is some rights issue - however I wonder why the installation process says that influxDB was correctly setup. BTW, the influxDB now indeed works again, but grafana not.
BTW, I āgreppedā for the DBname to find config files that hold any such informationā¦so it should be fairly accurate.
openhabian@openhabian:/ $ cat ./srv/openhab-conf/services/influxdb.cfg
url=http://localhost:8086
user=openhab
password=myoldpwd
db= myoldDB
retentionPolicy=autogen
openhabian@openhabian:/ $ cat ./srv/openhab-userdata/config/org/openhab/influxdb.config
:org.apache.felix.configadmin.revision:=L"16"
db="myoldDB"
password="myoldpwd"
retentionPolicy="autogen"
service.pid="org.openhab.influxdb"
url="http://localhost:8086"
user="openhab"
And, I can also not access influx via the web interface http://192.168.178.111:8086
The debug log shows that the installation of influxdb, create users, db went ok.
Grafana, as you already stated, seems to have a problem.
Check if grafana is running and on which port it is running:
sudo netstat -tulpn |grep -i grafana
Grafana seems not to be up and / or listening on port 3000.
There must be something in the log files e.g. /var/log/granfana/grafana.log
Check if journalctl shows a granfana related message:
sudo journalctl | grep -i grafana
Could be that there is a problem with permissions to create a pid file or to create a log file.
In that case check permissions of /var/log/grafana directory.
But journalctl should give a hint in that case.
There is a bigger issue. I restarted the Raspi (before I stopped openhab, influx) and again there is no influx working. So the problem we thought is solved, is actually not.
jfyi: auth-enabled = false in the influxdb config.
show users
in influx again shows no admin users. how can that be? I only restarted the Raspiā¦
I installed now influx&grafana once again via openhabian-configā¦
no show users
s shows:
user admin
AlexollonAdmin true
AlexollonOpenhab false
AlexollonGrafana false
I ran the 2 commandsā¦here is the outcome. There is a āpermission deniedā error on /var/log/grafana/grafana.log
**openhabian@openhabian**:**/ $** sudo netstat -tulpn |grep -i grafana
**openhabian@openhabian**:**/ $** sudo journalctl | grep -i grafana
Jan 07 17:41:19 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:41:31 openhabian **grafana**-server[856]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:31 openhabian **grafana**-server[856]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:31 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:41:31 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:41:31 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 1.
Jan 07 17:41:31 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:41:31 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:41:32 openhabian **grafana**-server[1114]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:32 openhabian **grafana**-server[1114]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:32 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:41:32 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:41:32 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 2.
Jan 07 17:41:32 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:41:32 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:41:32 openhabian **grafana**-server[1135]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:32 openhabian **grafana**-server[1135]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:33 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 3.
Jan 07 17:41:33 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:41:33 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:41:33 openhabian **grafana**-server[1188]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:33 openhabian **grafana**-server[1188]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:33 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:41:33 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:41:33 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 4.
Jan 07 17:41:34 openhabian **grafana**-server[1228]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:34 openhabian **grafana**-server[1228]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:34 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:41:34 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:41:34 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 5.
Jan 07 17:41:34 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:41:34 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:41:34 openhabian **grafana**-server[1261]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:34 openhabian **grafana**-server[1261]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:41:34 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 6.
Jan 07 17:41:34 openhabian systemd[1]: **grafana**-server.service: Start request repeated too quickly.
Jan 07 17:41:34 openhabian systemd[1]: Failed to start **Grafana** instance.
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: ts=2022-01-07T16:52:44.103758Z lvl=info msg="Executing query" log_id=0YuN9HeW000 service=query query="CREATE USER Alexollon**Grafana** WITH PASSWORD [REDACTED]"
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: [httpd] 127.0.0.1 - AlexollonAdmin [07/Jan/2022:17:52:44 +0100] "POST /query HTTP/1.1 {'q': 'CREATE USER Alexollon**Grafana** WITH PASSWORD '12345678''}" 200 33 "-" "curl/7.74.0" 3bf3d97e-6fda-11ec-8009-e45f01610c46 128411
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: ts=2022-01-07T16:52:44.255562Z lvl=info msg="Executing query" log_id=0YuN9HeW000 service=query query="SET PASSWORD FOR Alexollon**Grafana** = [REDACTED]"
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: [httpd] 127.0.0.1 - AlexollonAdmin [07/Jan/2022:17:52:44 +0100] "POST /query HTTP/1.1 {'q': 'SET PASSWORD FOR Alexollon**Grafana** = '12345678''}" 200 33 "-" "curl/7.74.0" 3c0b0656-6fda-11ec-800a-e45f01610c46 132079
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: ts=2022-01-07T16:52:44.412772Z lvl=info msg="Executing query" log_id=0YuN9HeW000 service=query query="GRANT READ ON dieKuchars TO Alexollon**Grafana**"
Jan 07 17:52:44 openhabian influxd-systemd-start.sh[5502]: [httpd] 127.0.0.1 - AlexollonAdmin [07/Jan/2022:17:52:44 +0100] "POST /query HTTP/1.1 {'q': 'GRANT READ ON dieKuchars TO Alexollon**Grafana**'}" 200 33 "-" "curl/7.74.0" 3c2300d8-6fda-11ec-800b-e45f01610c46 2233
Jan 07 17:52:47 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:52:47 openhabian **grafana**-server[5646]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:47 openhabian **grafana**-server[5646]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:47 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:52:47 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:52:47 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 1.
Jan 07 17:52:47 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:52:48 openhabian **grafana**-server[5665]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:48 openhabian **grafana**-server[5665]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:48 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:52:48 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:52:48 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 2.
Jan 07 17:52:48 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:52:48 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:52:48 openhabian **grafana**-server[5675]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:48 openhabian **grafana**-server[5675]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:48 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 3.
Jan 07 17:52:49 openhabian **grafana**-server[5689]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:49 openhabian **grafana**-server[5689]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:49 openhabian systemd[1]: **grafana**-server.service: Main process exited, code=exited, status=1/FAILURE
Jan 07 17:52:49 openhabian systemd[1]: **grafana**-server.service: Failed with result 'exit-code'.
Jan 07 17:52:49 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 4.
Jan 07 17:52:49 openhabian systemd[1]: Stopped **Grafana** instance.
Jan 07 17:52:49 openhabian systemd[1]: Started **Grafana** instance.
Jan 07 17:52:49 openhabian **grafana**-server[5700]: Failed to start **grafana**. error: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:49 openhabian **grafana**-server[5700]: failed to initialize file handler: open /var/log/**grafana**/**grafana**.log: permission denied
Jan 07 17:52:49 openhabian systemd[1]: **grafana**-server.service: Scheduled restart job, restart counter is at 5.
Jan 07 17:52:49 openhabian systemd[1]: **grafana**-server.service: Start request repeated too quickly.
Jan 07 17:52:49 openhabian systemd[1]: Failed to start **Grafana** instance.
So I checked rights on this directory:
openhabian@openhabian:/var/log $ la
total 9.5M
drwxr-xr-x 1 root root 4.0K Jan 7 17:17 ./
drwxr-xr-x 11 root root 4.0K Jan 5 15:22 ../
-rw-rw-r-- 1 root root 18K Jan 5 15:20 alternatives.log
drwxrwxr-x 2 root root 4.0K Jan 5 15:21 apt/
-rw-rw---- 1 root adm 18K Jan 7 17:58 auth.log
-rw-rw-r-- 1 root root 0 Oct 30 13:29 bootstrap.log
-rw-rw---- 1 root utmp 0 Oct 30 13:29 btmp
-rw-rw---- 1 root adm 3.6M Jan 7 18:02 daemon.log
-rw-rw---- 1 root adm 25K Jan 7 17:51 debug
-rw-rw-r-- 1 root root 110K Jan 5 15:21 dpkg.log
-rw-rw-r-- 1 root root 24K Jan 5 15:21 faillog
-rw-rw-r-- 1 root root 484 Jan 5 15:16 fontconfig.log
drwxr-xr-x 2 root root 4.0K Jan 5 16:01 grafana/
drwxr-sr-x+ 1 root systemd-journal 4.0K Oct 30 13:29 journal/
-rw-rw---- 1 root adm 585K Jan 7 17:17 kern.log
-rw-rw-r-- 1 root utmp 286K Jan 7 17:41 lastlog
-rw-rw---- 1 root adm 551K Jan 7 17:17 messages
drwxrwxr-x 1 openhab openhabian 4.0K Jan 7 17:41 openhab/
drwx------ 2 root root 4.0K Oct 30 13:29 private/
drwxrwxr-x 3 root root 4.0K Oct 30 13:13 runit/
drwxr-x--- 1 root root 4.0K Jan 7 17:44 samba/
-rw-rw---- 1 root adm 4.2M Jan 7 18:02 syslog
drwxrwxr-x 2 root root 4.0K Feb 2 2021 sysstat/
drwxrwxr-x 2 root root 4.0K Jan 5 15:15 unattended-upgrades/
-rw-rw---- 1 root adm 8.1K Jan 7 17:17 user.log
-rw-rw-r-- 1 root utmp 13K Jan 7 17:41 wtmp
lrwxrwxrwx 1 root root 32 Jan 5 15:21 zram-config -> /usr/local/share/zram-config/log/
But my main problem remains: InfluxDB does not work after restarting the Raspi.
the dir needs to be owned by grafana:grafana
so this is the reason why grafana does not start.
The above and
could be caused by ZRAM.
ZRAM is a āmirrorā for a set of directories in memory.
The explanation would be that the install was done in ZRAM and checked in ZRAM but not saved back to the SD card. When Pi is booted again data is copied again from SD card back to ZRAM. In case it was missing on SD it is missing in ZRAM, too.
In such cases I disable ZRAM. Make sure that the installation first works without using ZRAM and then make sure that ZRAM is enabled again.
Well, the good thing is: Grafana works again, however I dont know how to change the databaseā¦but that is a minor issue.
Bigger is that persistence again does not work, ie no data is shown in graphs of openhab web interface. There is no error anymore, users in influx look good. Still, does not work.
I give up now. I need to do a full reinstall.
Still I learnt a lot (and saved a lot of learnings for the future) - thank you Wolfgang!
one last question: I did a backup of the openhabian config out of the config tool as I dont want to enter all the THINGS and ITEMS data again. But I am worried that I will take the problems with me. Does this config data also include influx and Grafana config files or just the openhab configuration stuff?
Yes and no.
Those part of the configuration for influxdb and grafana that is stored under /etc/grafana resp. /etc/influxdb/ is not part of the backup that is created with āopenhab-cli backup
ā
But the part that is configured within openhab is part of the backup e.g. in files ( path within the zip file ):
./userdata/config/org/openhab/core/ui/tiles.config
./conf/services/runtime.cfg
./conf/services/influxdb.cfg
Thx a lot Wolfgang. Then I will try to import the settings from the backup, but before that make a copy of the influxdb.cfg file. the others I assume are not relevant (but I will look at them first).
Iām running OH on an Ubuntu 20.04 LTS server system. And Iām so much hating InfluxDB setupā¦
Installed and running v 2.1.1, but no commands will be accepted at the CLI. For example, an attempt to create an InfluxDB org:
root@server:~# influx org create -n openhab-org
Is met with the response
Error: failed to create org "openhab-org": 401 Unauthorized: unauthorized access
I receive this response for any command and unable (or am unaware how) to in any way edit my configuration. The InfluxDB documentation is horrible to comprehend and the community support is thin to non-existent. Any and all help, please!
I find that for influxdb 2 the web UI is by far the easiest way to configure it. Can be reached at http://<IP-adress>:8086
Good morning Influx fans:)
Another day, another questionā¦
I did a full new clean installation of OH3.2 and influx on Raspberry Pi4b. all standard per openhabian-config.
I configured persistance in openhabian:8080 to influx and it is working as well. Data is recorded properly and I can access it in Grafana (also this installation was successful).
two questions tough:
openhabian@openhabian:/etc/influxdb $ cat influxdb.conf | grep -v "#" | grep -v "^$"
[meta]
dir = "/var/lib/influxdb/meta"
[data]
dir = "/var/lib/influxdb/data"
wal-dir = "/var/lib/influxdb/wal"
series-id-set-cache-size = 100
[coordinator]
[retention]
[shard-precreation]
[monitor]
store-enabled = false
[http]
enabled = true
bind-address = "localhost:8086"
auth-enabled = true
[logging]
[subscriber]
[[graphite]]
[[collectd]]
[[opentsdb]]
[[udp]]
[continuous_queries]
[tls]
openhabian@openhabian:/ $ influx
Connected to http://localhost:8086 version 1.8.10
InfluxDB shell version: 1.8.10
> show users
ERR: unable to parse authentication credentials
Warning: It is possible this error is due to not setting a database.
Please set a database with the command "use <database>".
> show databases
More infos:
sudo systemctl status influxdb
ā influxdb.service - InfluxDB is an open-source, distributed, time series database
Loaded: loaded (/lib/systemd/system/influxdb.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2022-01-07 21:06:42 CET; 13h ago
Docs: https://docs.influxdata.com/influxdb/
Main PID: 5595 (influxd)
Tasks: 14 (limit: 4915)
CPU: 3min 3.908s
CGroup: /system.slice/influxdb.service
āā5595 /usr/bin/influxd -config /etc/influxdb/influxdb.conf
Jan 08 10:20:13 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:13 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:14 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:14 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:15 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:15 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:16 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:16 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:17 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:17 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:18 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:18 +0100] "POST /write?db=dieKucharsOH>
Jan 08 10:20:19 openhabian influxd-systemd-start.sh[5595]: [httpd] 127.0.0.1 - AlexollonOpenhab [08/Jan/2022:10:20:19 +0100] "POST /write?db=dieKucharsOH
Setup tech info:
runtimeInfo:
version: 3.2.0
buildString: Release Build
locale: de-AT
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.13
javaVendor: Azul Systems, Inc.
javaVendorVersion: Zulu11.52+13-CA
osName: Linux
osVersion: 5.10.63-v7l+
osArchitecture: arm
availableProcessors: 4
freeMemory: 58586424
totalMemory: 194904064
bindings:
- coronastats
- fronius
- hue
- netatmo
- network
- systeminfo
clientInfo:
device:
ios: false
android: false
androidChrome: false
desktop: true
iphone: false
ipod: false
ipad: false
edge: false
ie: false
firefox: false
macos: true
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
webView: false
webview: false
standalone: false
os: macos
pixelRatio: 2
prefersColorScheme: light
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: N/A
language: de-DE
languages:
- de-DE
onLine: true
platform: MacIntel
screen:
width: 2560
height: 1440
colorDepth: 24
support:
touch: false
pointerEvents: true
observer: true
passiveListener: true
gestures: false
intersectionObserver: true
themeOptions:
dark: light
filled: true
pageTransitionAnimation: default
bars: filled
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko) Version/15.1 Safari/605.1.15
timestamp: 2022-01-08T09:23:34.014Z
this is because authentication is enabled.
If authentication is enabled and user/passwords are set then you need to authenticate first:
influx -username YourUserNameHere -password YourPasswordHere
Looks like authentication is enabled.
You first need to logon with username/password
influx -username YourAdminAccount -password YourAdminsPassword
If an admin account is not already set. Disable authentication. Restart influxdb.
Connect to influx. Create an admin account. Set an admin accountās password. Enable authentication. Restart influxdb again.
Hi @Wolfgang_S, thank you for the response. Iām using V2, which according to documentation does not use authentication but uses tokens. Now it happens that I need to use a token to get OH to write to the Influxdb bucket (and some OH documentation suggests I do not) so that may be an issue.
Your login suggestion unfortunately does not work; it is not the correct syntax (for example ā-usernameā is not recognized, correct would be ā-nā; your suggestion is for V1?). So I still cannot make any edits within the CLIā¦
Youāre right. That answer is based on knowledge about influxdb v1. Sorry, for that.
Did you try ( see Install InfluxDB | InfluxDB OSS v2 Documentation )
influx setup
You will be asked to enter:
Running
influx auth list
will show the configured token and other information.
Iāve already run
influx setup
and I can see those values through the API (browser, /api/v2/authorizations). But I still cannot make any edits through the CLI. It almost seems like a folders permission issue but it is likely a lack of admin access, which I cannot seem to grant.
Have you done this step?
Or have you tried the web UI? Itās really easy to create users and tokens that way.
