This is my grafana.log on /var/log/grafana
t=2019-03-07T01:42:58+0100 lvl=info msg="cleanup of expired auth tokens done" logger=auth count=0
t=2019-03-07T13:42:58+0100 lvl=info msg="cleanup of expired auth tokens done" logger=auth count=0
t=2019-03-07T21:56:57+0100 lvl=info msg="Shutdown started" logger=server reason="System signal: terminated"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped PluginManager" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped CleanUpService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped UserAuthTokenService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped Stream Manager"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped ProvisioningService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped NotificationService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped InternalMetricsService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped RenderingService" logger=server reason=nil
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped TracingService" logger=server reason=nil
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped AlertingService" logger=server reason="context canceled"
t=2019-03-07T21:56:57+0100 lvl=info msg="Stopped HTTPServer" logger=server reason=nil
t=2019-03-07T21:56:57+0100 lvl=eror msg="Server shutdown" logger=server reason="System signal: terminated"
t=2019-03-07T21:57:31+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-07T21:57:32+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-12T22:22:04+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-12T22:22:05+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-12T22:22:06+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-13T21:45:27+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-13T21:45:28+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-13T21:45:29+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-16T10:38:21+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-16T10:38:22+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-16T10:38:23+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-21T17:32:58+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-21T17:32:59+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-26T22:31:16+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-26T22:31:17+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-26T23:46:24+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-26T23:46:25+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:45:28+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:45:29+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:49:13+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:49:14+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:50:18+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:50:19+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:54:16+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:54:17+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T22:54:18+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-03-27T23:20:40+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-27T23:20:41+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-27T23:21:08+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-27T23:21:09+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-29T18:42:59+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-29T18:43:00+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-29T20:17:15+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-29T20:17:16+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-29T20:17:17+0100 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-31T23:56:53+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-03-31T23:56:54+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T00:30:18+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T00:30:19+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T02:01:57+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T02:01:58+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T02:01:59+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T23:51:17+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T23:51:18+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T23:51:19+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T23:51:41+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-01T23:51:42+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:42:23+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:42:24+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:42:25+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:47:33+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:47:34+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:48:05+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:48:06+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:48:07+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:48:28+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T00:48:29+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: 300##################### Grafana Configuration Example #####################\n"
t=2019-04-02T18:55:13+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T18:55:14+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:03+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:04+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:05+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:06+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:15+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T20:00:16+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:11:30+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:11:31+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:22:03+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:22:04+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:38:09+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:38:10+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:38:11+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:58:54+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-02T23:58:55+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:11:31+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:11:32+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:11:33+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:11:46+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:11:47+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:20:38+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:20:39+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:29:00+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:29:01+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:39:11+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-03T00:39:12+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T22:40:44+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T22:40:45+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T22:40:46+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T22:42:58+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T22:42:59+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:04:49+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:04:50+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:08:45+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:08:46+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:08:47+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:44:09+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-04T23:44:10+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-05T00:00:55+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-05T00:00:56+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-05T00:00:57+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-06T20:30:05+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-06T20:30:06+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-07T17:29:24+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-07T17:29:25+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-10T21:53:00+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
t=2019-04-10T21:53:01+0200 lvl=crit msg="Failed to parse /etc/grafana/grafana.ini, key-value delimiter not found: ...\n"
