InfluxDB Jave Driver and Port 3000
All,
I tried to set up the influxDB on Openhab 5.0 the stable one. I run into two issues first the port 3000 is also used from zwave JS might be when a information when you install the add on helps other users. So I manged it and change the port.
But I still get the problem with the java driver and here I have no clue at all, has anybody an idea with the Java driver?
Regards
Franz
What problem? The InfluxDB driver library is part of the add-on. You shouldn’t need to do anything at all.
I test it again. I get the following with journal -f:
openhabian influxd-systemd-start.sh[971]: [httpd] 127.0.0.1 - - [03/Nov/2025:13:36:09 +0000] “GET /ping HTTP/1.1” 204 0 “-” “influxdb-client-java/unknown” 0ead0867-b8ba-11f0-82e6-dca632fcbad9 40
Nov 03 13:36:10 openhabian influxd-systemd-start.sh[971]: [httpd] 127.0.0.1 - - [03/Nov/2025:13:36:10 +0000] "POST /api/v2/write?org=openhab&bucket=autogen&precision=ms HTTP/1.1 " 401 55 “-” “influxdb-client-java/unknown” 0f35591e-b8ba-11f0-82e7-dca632fcbad9 112
and on the log:
Logger Class
com.influxdb.client.write.events.WriteErrorEvent
With a very long stack trace
