im really new to all of this.
I installed OH3 on an Pi3.
Over raspi-config i installed InfluxDB+Grafana.
The shelly 1PM is the first and only item in my system. I configured everything over the PaperUI. I can control the the switch and the power is displayed in OH3. Now i want to make a nice graph with grafana. But when i try to choose which data should be displayed in grafana but the list is empty.
Does anybody has a tip for me?
UPDATE:
I reinstalled Openhabian but the problem remains.
I looked in the log.
2021-09-25 09:44:09.766 [DEBUG] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service is being activated
2021-09-25 09:44:09.773 [DEBUG] [.influxdb.InfluxDBPersistenceService] - Loaded configuration {component.name=org.openhab.persistence.influxdb.InfluxDBPersistenceService, url=http://localhost:8086, retentionPolicy=autogen, service.config.category=persistence, service.config.description.uri=persistence:influxdb, user=influxdb, version=V2, service.config.label=InfluxDB Persistence Service, service.pid=[org.openhab.influxdb, org.openhab.influxdb], service.config.factory=false, component.id=289, password=xxxxxxx, db=openhab}
2021-09-25 09:44:11.767 [WARN ] [b.client.internal.InfluxDBClientImpl] - The exception occurs during check instance readiness
com.influxdb.exceptions.NotFoundException: null
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:104) ~[bundleFile:?]
at com.influxdb.internal.AbstractRestClient.execute(AbstractRestClient.java:81) ~[bundleFile:?]
at com.influxdb.client.internal.InfluxDBClientImpl.ready(InfluxDBClientImpl.java:246) [bundleFile:?]
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.connect(InfluxDB2RepositoryImpl.java:95) [bundleFile:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.activate(InfluxDBPersistenceService.java:115) [bundleFile:?]
2021-09-25 09:44:11.786 [DEBUG] [rnal.influx2.InfluxDB2RepositoryImpl] - Succesfully connected to InfluxDB. Instance ready=null
2021-09-25 09:44:13.150 [WARN ] [b.client.internal.InfluxDBClientImpl] - The exception occurs during check instance readiness
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.checkConnectionStatus(InfluxDB2RepositoryImpl.java:122) [bundleFile:?]
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.connect(InfluxDB2RepositoryImpl.java:98) [bundleFile:?]
2021-09-25 09:44:13.166 [WARN ] [rnal.influx2.InfluxDB2RepositoryImpl] - database not ready
2021-09-25 09:44:13.170 [DEBUG] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service is now activated
2021-09-25 09:44:13.175 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.1.0 (244)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(289)] : invoked activate: activate
2021-09-25 09:44:13.185 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.1.0 (244)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(289)] : Set implementation object for component
2021-09-25 09:44:13.190 [DEBUG] [.influxdb.InfluxDBPersistenceService] - bundle org.openhab.persistence.influxdb:3.1.0 (244)[org.openhab.persistence.influxdb.InfluxDBPersistenceService(289)] : Changed state from satisfied to active
2021-09-25 09:44:13.229 [DEBUG] [.influxdb.InfluxDBPersistenceService] - Got a query for historic points!
2021-09-25 09:44:13.511 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@236fe1eb': null
com.influxdb.exceptions.ForbiddenException: null
at com.influxdb.internal.AbstractRestClient.responseToError(AbstractRestClient.java:102) ~[?:?]
at com.influxdb.internal.AbstractQueryApi$1.onResponse(AbstractQueryApi.java:145) ~[?:?]
at com.influxdb.internal.AbstractQueryApi.query(AbstractQueryApi.java:193) ~[?:?]
at com.influxdb.internal.AbstractQueryApi.query(AbstractQueryApi.java:104) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:803) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:105) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:83) ~[?:?]
at com.influxdb.client.internal.QueryApiImpl.query(QueryApiImpl.java:73) ~[?:?]
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.query(InfluxDB2RepositoryImpl.java:182) ~[?:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.query(InfluxDBPersistenceService.java:231) ~[?:?]
Direct after the line “Got a query for historic points” i got an error.
Does this mean there is some data which can be stored but there is a problem with ‘QueryablePersistenceService.query()’?
GOT IT!
I had an false User in my .conf file
