After upgrading to OH3, I get InfluxDB exceptions like this and it seems that the Persistence layer is not working at all:
2020-12-23 13:58:08.573 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
org.influxdb.InfluxDBException$FieldTypeConflictException: partial write: field type conflict: input field "value" on measurement "miAirScreenStatus" is type integer, already exists as type float dropped=1
at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:144) ~[bundleFile:?]
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.write(InfluxDBImpl.java:460) ~[bundleFile:?]
at org.influxdb.impl.OneShotBatchWriter.write(OneShotBatchWriter.java:22) ~[bundleFile:?]
at org.influxdb.impl.BatchProcessor.write(BatchProcessor.java:340) [bundleFile:?]
at org.influxdb.impl.BatchProcessor$1.run(BatchProcessor.java:287) [bundleFile:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
im running in same problem that influxdb isn’t working anymore, i already aplied above fix and getting this spammed in my log:
2020-12-30 08:30:30.035 [ERROR] [org.influxdb.impl.BatchProcessor ] - Batch could not be sent. Data will be lost
at okio.Segment.push(Segment.java:111) ~[bundleFile:?]
at okio.Buffer.writableSegment(Buffer.java:1307) ~[bundleFile:?]
at okio.Buffer.writeUtf8(Buffer.java:980) ~[bundleFile:?]
at okio.Buffer.writeUtf8(Buffer.java:961) ~[bundleFile:?]
at okio.RealBufferedSink.writeUtf8(RealBufferedSink.java:53) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.writeRequest(Http1ExchangeCodec.java:196) ~[bundleFile:?]
at okhttp3.internal.http1.Http1ExchangeCodec.writeRequestHeaders(Http1ExchangeCodec.java:141) ~[bundleFile:?]
at okhttp3.internal.connection.Exchange.writeRequestHeaders(Exchange.java:72) ~[bundleFile:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[bundleFile:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[bundleFile:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[bundleFile:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[bundleFile:?]
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93) ~[bundleFile:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[bundleFile:?]
at org.influxdb.impl.BasicAuthInterceptor.intercept(BasicAuthInterceptor.java:22) ~[bundleFile:?]
at org.influxdb.impl.GzipRequestInterceptor.intercept(GzipRequestInterceptor.java:42) ~[bundleFile:?]
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.java:152) ~[bundleFile:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[bundleFile:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[bundleFile:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:188) ~[bundleFile:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:819) ~[bundleFile:?]
after a influxdb binding restart, it runs ok for a while, but then returns with this again.
