Since a day, nothing gets written to my InfluxDB anymore. I do read from the database using some rules, and that works, so the connection is active. I switched on debug logging and don’t see anything in the log on writing persistence data.
I tried the REST API to query the items in the influxdb persistence and I get an empty response.
When I change the persistence file, I get the follow error in the log file:
2017-02-28 18:37:38.531 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'influxdb.persist'
2017-02-28 18:37:38.570 [WARN ] [.core.persistence.PersistenceManager] - Failed to delete cron job for dbId 'influxdb'
2017-02-28 18:37:38.702 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'influxdb.persist'
2017-02-28 18:37:38.718 [ERROR] [.core.internal.folder.FolderObserver] - Error handling update of file '/etc/openhab2/persistence/influxdb.persist': null.
java.lang.NullPointerException
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.removeFutures(ExpressionThreadPoolManager.java:321)[100:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.remove(ExpressionThreadPoolManager.java:291)[100:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.scheduler.ExpressionThreadPoolManager$ExpressionThreadPoolExecutor.remove(ExpressionThreadPoolManager.java:308)[100:org.eclipse.smarthome.core:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.removeTimers(PersistenceManagerImpl.java:321)[105:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.stopEventHandling(PersistenceManagerImpl.java:377)[105:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.core.persistence.internal.PersistenceManagerImpl.removeConfig(PersistenceManagerImpl.java:348)[105:org.eclipse.smarthome.core.persistence:0.9.0.b4]
at org.eclipse.smarthome.model.persistence.internal.PersistenceModelManager.modelChanged(PersistenceModelManager.java:85)[127:org.eclipse.smarthome.model.persistence:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[124:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[124:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[124:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[124:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[124:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[100:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
Here is my persistence file:
Strategies {
everyDay : "0 0 0 * * ?"
every5Min: "0 0/5 5-23 * * ?"
default = everyChange
Items {
gPVEtotal*, gPVEtoday*, gPVPower*, gPVEmeter* : strategy = every5Min, everyDay
gEmeter*, Warmtepomp : strategy = everyChange
I am on OH2 release version running on a RaspberryPi 3 with openhabian. Does anyone have any suggestions?
