I’m using 3.3M1. I have Influx 1.6.2-1 installed as a persistence service. This works fine. But whenever I update the persistence file, influxdb.persist, I get a slew of errors. Strangely, the persistence appears to continue to work just fine. As far as I can tell the only issue is the error messages, but I am worried that something else could be amiss. This is a sample of the error in the log. I don’t know how to debug this further. Where did it find the ‘.2’ on line 1? What is it looking at?
I know Influx version 2 is out and some are using it. Does OH3.3 assume Influx2 is being used? Is that the issue?
thanks
2022-02-27 16:24:29.972 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'QueryablePersistenceService.query()' on 'org.openhab.persistence.influxdb.InfluxDBPersistenceService@5dd39c01': error parsing query: found .2, expected ; at line 1, char 49
org.influxdb.InfluxDBException: error parsing query: found .2, expected ; at line 1, char 49
at org.influxdb.InfluxDBException.buildExceptionFromErrorMessage(InfluxDBException.java:161) ~[?:?]
at org.influxdb.InfluxDBException.buildExceptionForErrorState(InfluxDBException.java:173) ~[?:?]
at org.influxdb.impl.InfluxDBImpl.execute(InfluxDBImpl.java:827) ~[?:?]
at org.influxdb.impl.InfluxDBImpl.executeQuery(InfluxDBImpl.java:814) ~[?:?]
at org.influxdb.impl.InfluxDBImpl.query(InfluxDBImpl.java:714) ~[?:?]
at org.openhab.persistence.influxdb.internal.influx1.InfluxDB1RepositoryImpl.query(InfluxDB1RepositoryImpl.java:155) ~[?:?]
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.query(InfluxDBPersistenceService.java:231) ~[?:?]
at jdk.internal.reflect.GeneratedMethodAccessor9244.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Method.java:566) ~[?:?]
at org.openhab.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:154) [bundleFile:?]
at org.openhab.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
