I seem to have a strange problem with my Openhab running in docker. For some reason I get this error:
2025-10-02 13:13:26.850 [ERROR] [icrometer.influx.InfluxMeterRegistry] - unable to create database ‘openhab’
java.net.SocketTimeoutException: Connect timed out
< a lot of java output >
I can at least ping and run curl http://:8086/health the influxdb server from within the docker container with working result. Since I have tried a lot of stuff both from the serivices file and from the UI I am afraid the config is somewhat broken If I uninstall the Influxdb add-on and reinstall it, removing the userdata/cache directory and restarting the docker container , the old configuration pops up. It even tries to connect to the influxdb even though the add-on is not installed. This container has moved between two servers with rsync , also cpu arch has changed from Intel to ARM. But since this is all java, it should not be a problem I guess ?
So is there a way to purge all the influxdb add-on data?
Both the InfluxDB and OpenHAB docker containers run on the same host.
I have done some more debugging by setting up an InfluxDB on another node and I ran tcpdump there to check if it actually tries to connect. And it seems that it does not. This is my services file:
DNS is working so nod1.mean.net can be resolved. The openHAB log says the following when starting so one might think that it actually can talk to the database:
2025-11-05 09:24:36.222 [DEBUG] [rnal.influx2.InfluxDB2RepositoryImpl] - Successfully connected to InfluxDB. Instance pingable=true
2025-11-05 09:24:36.232 [DEBUG] [rnal.influx2.InfluxDB2RepositoryImpl] - database status is OK
2025-11-05 09:24:36.233 [INFO ] [.influxdb.InfluxDBPersistenceService] - InfluxDB persistence service started.
After that I only get these errors:
2025-11-05 09:57:45.097 [ERROR] [icrometer.influx.InfluxMeterRegistry] - unable to create database 'openhab'
at sun.nio.ch.NioSocketImpl.timedFinishConnect(NioSocketImpl.java:546) ~[?:?]
at sun.nio.ch.NioSocketImpl.connect(NioSocketImpl.java:592) ~[?:?]
at java.net.Socket.connect(Socket.java:751) ~[?:?]
at sun.net.NetworkClient.doConnect(NetworkClient.java:178) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:531) ~[?:?]
at sun.net.www.http.HttpClient.openServer(HttpClient.java:636) ~[?:?]
at sun.net.www.http.HttpClient.<init>(HttpClient.java:282) ~[?:?]
at sun.net.www.http.HttpClient.New(HttpClient.java:386) ~[?:?]
at sun.net.www.http.HttpClient.New(HttpClient.java:408) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:1320) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1253) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1139) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:1068) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1462) ~[?:?]
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1433) ~[?:?]
at io.micrometer.core.ipc.http.HttpUrlConnectionSender.send(HttpUrlConnectionSender.java:98) ~[?:?]
at io.micrometer.core.ipc.http.HttpSender$Request$Builder.send(HttpSender.java:306) ~[?:?]
at io.micrometer.influx.InfluxMeterRegistry.createDatabaseIfNecessary(InfluxMeterRegistry.java:113) ~[?:?]
at io.micrometer.influx.InfluxMeterRegistry.publish(InfluxMeterRegistry.java:125) ~[?:?]
at io.micrometer.core.instrument.push.PushMeterRegistry.publishSafelyOrSkipIfInProgress(PushMeterRegistry.java:64) ~[?:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572) ~[?:?]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:358) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:305) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642) ~[?:?]
at java.lang.Thread.run(Thread.java:1583) [?:?]
2025-11-05 09:57:46.117 [ERROR] [icrometer.influx.InfluxMeterRegistry] - failed to send metrics to influx
at io.micrometer.influx.InfluxMeterRegistry.publish(InfluxMeterRegistry.java:149) ~[?:?]
Anyone having any pointers ? Or can I just skip this and make OpenHAB push all the values from my devices to a MQTT topic instead ?
PING influxdb2 (172.18.0.4) 56(84) bytes of data.
64 bytes from influxdb2.services_default (172.18.0.4): icmp_seq=1 ttl=64 time=0.068 ms
64 bytes from influxdb2.services_default (172.18.0.4): icmp_seq=2 ttl=64 time=0.062 ms
