i’m seeing quite a lot of warnings in the log, followed with bunch of javaerror regarding ping fo the influxdb2
I’m running influx on external LXC within the same Proxmox as OH LXC for years now … and it is definitely running just fine, everything works as expected, influx lxc has got nonstop uptime and it’s always started before OH bootup.
Yet, there is a lot of warnings about database not ready, or persistence not available.
Is it something known or can i supress this annoying log filler somehow?
Thank you
2026-09-13 09:59:46.822 [WARN ] [influxdb.internal.AbstractRestClient] - Ping request wasn't successful
java.io.InterruptedIOException: interrupted
at okio.Timeout.throwIfReached(Timeout.kt:109)
at okio.OutputStreamSink.write(JvmOkio.kt:54)
at okio.AsyncTimeout$sink$1.write(AsyncTimeout.kt:151)
at okio.RealBufferedSink.flush(RealBufferedSink.kt:268)
at okhttp3.internal.http1.Http1ExchangeCodec.finishRequest(Http1ExchangeCodec.kt:155)
at okhttp3.internal.connection.Exchange.finishRequest(Exchange.kt:95)
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.kt:79)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.kt:109)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.kt:34)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.kt:95)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.kt:83)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.kt:76)
at com.influxdb.client.internal.GzipInterceptor.intercept(GzipInterceptor.java:91)
at okhttp3.logging.HttpLoggingInterceptor.intercept(HttpLoggingInterceptor.kt:154)
at com.influxdb.client.internal.AuthenticateInterceptor.intercept(AuthenticateInterceptor.java:103)
at com.influxdb.internal.UserAgentInterceptor.intercept(UserAgentInterceptor.java:60)
at okhttp3.internal.connection.RealCall.getResponseWithInterceptorChain$okhttp(RealCall.kt:201)
at okhttp3.internal.connection.RealCall.execute(RealCall.kt:154)
at retrofit2.OkHttpCall.execute(OkHttpCall.java:207)
at com.influxdb.internal.AbstractRestClient.ping(AbstractRestClient.java:194)
at com.influxdb.client.internal.InfluxDBClientImpl.ping(InfluxDBClientImpl.java:277)
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.checkConnectionStatus(InfluxDB2RepositoryImpl.java:127)
at org.openhab.persistence.influxdb.internal.influx2.InfluxDB2RepositoryImpl.connect(InfluxDB2RepositoryImpl.java:104)
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.checkConnection(InfluxDBPersistenceService.java:278)
at org.openhab.persistence.influxdb.InfluxDBPersistenceService.query(InfluxDBPersistenceService.java:246)
at org.openhab.core.persistence.extensions.PersistenceExtensions.internalPersistedState(PersistenceExtensions.java:354)
at org.openhab.core.persistence.extensions.PersistenceExtensions.getAllStatesBetweenWithBoundaries(PersistenceExtensions.java:3683)
at org.openhab.core.persistence.extensions.PersistenceExtensions.internalMinimumBetween(PersistenceExtensions.java:1148)
at org.openhab.core.persistence.extensions.PersistenceExtensions.minimumSince(PersistenceExtensions.java:1056)
at java.base/jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103)
at java.base/java.lang.reflect.Method.invoke(Method.java:580)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1195)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeOperation(XbaseInterpreter.java:1170)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._invokeFeature(XbaseInterpreter.java:1156)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.invokeFeature(XbaseInterpreter.java:1101)
at org.openhab.core.model.script.interpreter.ScriptInterpreter.invokeFeature(ScriptInterpreter.java:148)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:881)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:243)
at org.openhab.core.model.script.interpreter.ScriptInterpreter.doEvaluate(ScriptInterpreter.java:219)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.internalEvaluate(XbaseInterpreter.java:227)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:877)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:528)
at org.openhab.core.model.script.interpreter.ScriptInterpreter._doEvaluate(ScriptInterpreter.java:234)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:257)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:936)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:287)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter._doEvaluate(XbaseInterpreter.java:475)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.doEvaluate(XbaseInterpreter.java:251)
at org.eclipse.xtext.xbase.interpreter.impl.XbaseInterpreter.evaluate(XbaseInterpreter.java:213)
at org.openhab.core.model.script.runtime.internal.engine.ScriptImpl.execute(ScriptImpl.java:80)
at org.openhab.core.model.script.runtime.internal.engine.DSLScriptEngine.eval(DSLScriptEngine.java:150)
at org.openhab.core.automation.module.script.internal.handler.AbstractScriptModuleHandler.eval(AbstractScriptModuleHandler.java:264)
at org.openhab.core.automation.module.script.internal.handler.ScriptActionHandler.execute(ScriptActionHandler.java:116)
at org.openhab.core.automation.internal.RuleEngineImpl.executeActions(RuleEngineImpl.java:1424)
at org.openhab.core.automation.internal.RuleEngineImpl.runRule(RuleEngineImpl.java:1137)
at org.openhab.core.automation.internal.TriggerHandlerCallbackImpl$TriggerData.run(TriggerHandlerCallbackImpl.java:86)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:572)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:317)
at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1144)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:642)
at java.base/java.lang.Thread.run(Thread.java:1583)
Suppressed: java.io.InterruptedIOException: interrupted
at okio.InputStreamSource.read(JvmOkio.kt:91)
at okio.AsyncTimeout$source$1.read(AsyncTimeout.kt:177)
at okio.RealBufferedSource.indexOf(RealBufferedSource.kt:457)
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.kt:350)
at okhttp3.internal.http1.HeadersReader.readLine(HeadersReader.kt:29)
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.kt:180)
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.kt:110)
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.kt:93)
... 76 more
2026-09-13 09:59:46.850 [WARN ] [rnal.influx2.InfluxDB2RepositoryImpl] - database not ready
