[INFO] Binding for cleaing robot BT CHUWI V7
don’t know if is the right place; i’d like to buy a Chuwi robot that use bluetooth and an android app to control it.
There is a way to make it compatibile with OH?
Rather, there is a way to sniff bluetooth commands and replicate it via openhab?
Thanks :slight_smile:
With OH 1 the answer is definitely no. The BT binding, for those who can get it to work, only tells you when a BT device is nearby or not.
There are updates to the BT binding for OH 2 which will be able to do more but that does not mean it will be able to work with any old BT device that comes along. I suppose it is theoretically possible to sniff the BT messages, assuming that it isn’t encrypted, but that is not going to be an easy task.
Ok thansk in advance. Probably isn’t a good solution :slight_smile:
Thanks for your help!
