i don’t know if this is the right section;
I’m currently using wview as weather station (and it reports data to an italian association (meteonetwork.it) and to wunderground).
Currently my weather station report also internal temperature (and humidity).
www.ssai.it/meteo/interna.htm
www.ssai.it/meteo/
There is a way to import this data on openhab?
thanks in advance!
thanks for your reply.
I’m already using this weather binding (take data from weather station with wview, send to wunderground and taken with weather binding).
Problem is that i can’t export internal temperature to wunderground!
Thanks!
I don’t send my internal readings anywhere other than my website though. I don’t know that WU has the ability to receive them either, as their schema seems pre-defined. If they do accept it though, it would probably be easier to alter wview to send the data directly instead of wview to OH to WU. An example of how to post data to WU can be found here: wunderfixer . The third thing that comes to mind, if you want to get data directly into OH is a binding for your weather station directly. Not sure which station you have, but if you have a Davis, there is a binding: davis-binding
Thanks for your help.
Unfortunately i don’t have a davis so i can’t use that binding
In wview i can’t modify data sent to WU; i had thought to change a parameter that i didn’t use but it’s impossibile.
Only thing that i can do is export data in a txt file with only interna temperature and himidity.
But then i don’t know how to import on OH!
thanks in advance!
ps: i’d like to buy a vantage because in future opensprinkler can use UV and solar radiation to calcolate evapotranspiration, but now i can’t
In the http binding, you can use a regular expression to parse data. I don’t have an example available right now, but I’ll reply again when I can with an example. You can also search the documentation for either regex or regular expression on the http binding section.
The way I have done this in the past is create two String Items, one for each value that I need to retrieve (note that this means that OpenHab makes 2 calls instead of just one, but I’m not sure of a better way right now.)
However, working on pulling the data from the URL you provided is proving tricky, because the label and value are on different lines from each other. I can’t seem to get the OpenHab regex engine to handle this situation. I’ll keep digging and let you know.
Hi i’m very beginner
i try to read a led status from remote relay shield on my internal lan.
on browser when i put http://192.168.1.201/status.xml
i receive
The following should update state every six seconds. It has the advantage of only pulling the XML every six seconds, but updating multiple items. You will need a different .xsl file for each item.
If you want to have buttons in openHAB change the state on the relay shield, you would have to add the appropriate “>[url:…]” bindings to the button switch items (assuming you can command your relay shield via HTTP).
