I did a fresh IDE install with the Eclipse installer
I create a new binding with create_openhab_binding_skeleton.sh
./create_openhab_binding_skeleton.sh MagentaTV "Markus Michels"
and run “mvn install” from the binding directory.
This results in:
[ERROR] Code Analysis Tool has found:
6 error(s)!
1 warning(s)
5 info(s)
[ERROR] .binding.magentatv/ESH-INF/binding/binding.xml:[5]
Cannot find the declaration of element binding:binding.
[ERROR] .binding.magentatv/ESH-INF/thing/thing-types.xml:[5]
Cannot find the declaration of element thing:thing-descriptions.
[ERROR] org.openhab.binding.magentatv.internal.MagentaTVConfiguration.java:[2]
Header line doesn't match pattern ^ \* Copyright \(c\) 2010-2019 Contributors to the openHAB project$
[WARNING] org.openhab.binding.magentatv.internal.MagentaTVConfiguration.java:[20]
Classes/Interfaces should be annotated with @NonNullByDefault
[ERROR] org.openhab.binding.magentatv.internal.MagentaTVHandler.java:[2]
[ERROR] org.openhab.binding.magentatv.internal.MagentaTVHandlerFactory.java:[2]
[ERROR] org.openhab.binding.magentatv.internal.MagentaTVBindingConstants.java:[2]
Those 2 are strange:
because binding.xml
<?xml version="1.0" encoding="UTF-8"?>
<binding:binding
id="magentatv" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:binding="http://eclipse.org/smarthome/schemas/binding/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/binding/v1.0.0 http://eclipse.org/smarthome/schemas/binding-1.0.0.xsd">
<name>MagentaTV Binding</name>
<description>This is the binding for MagentaTV receivers.</description>
<author>Markus Michels</author>
</binding:binding>
as well as thing-types.xml have those declarations
<thing:thing-descriptions bindingId="magentatv"
xmlns:thing="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0"
xsi:schemaLocation="http://eclipse.org/smarthome/schemas/thing-description/v1.0.0 http://eclipse.org/smarthome/schemas/thing-description-1.0.0.xsd">
</thing:thing-descriptions>
The wrong © format could be easily fixed, but obviously the checkstyle templates are not correct.
How could I create a clean skeleton?
