- Platform information:
- Hardware: Raspberry Pi 3B+
- OS: frehsly flashed openhabian from the latest image
- Java Runtime Environment: should have been installed during setup
- openHAB version: the latest 1.4.1 (https://github.com/openhab/openhabian/releases/tag/v1.4.1)
- Issue of the topic: After flashing the new micro sd card with the latest image downloaded today, the initial setup on a RaspberryPI 3B+ failed during installation of the embedded Zulu OpenJDK. Most likely due to a path error?
I tried to do the setup again, with no effect. Since I am new to openhab, is there anything I could do better? I found several installation issues in this community but none with the error below.
I would appreciate any advice! Thank you so much in advance!
the complete installation log is as follows (first-boot.log):
2018-03-13_22:53:35_UTC [openHABian] Starting the openHABian initial setup.
2018-03-13_22:53:35_UTC [openHABian] Storing configuration… OK
2018-03-13_22:53:35_UTC [openHABian] Changing default username and password… OK
2018-03-13_22:53:36_UTC [openHABian] Setting up Ethernet connection… OK
2018-03-13_22:53:36_UTC [openHABian] Ensuring network connectivity… OK
2018-03-13_22:53:38_UTC [openHABian] Waiting for dpkg/apt to get ready… OK
2018-03-13_22:53:52_UTC [openHABian] Updating repositories and upgrading installed packages… OK
2019-03-20_15:24:46_UTC [openHABian] Installing git package… OK
2019-03-20_15:25:18_UTC [openHABian] Cloning myself… OK
2019-03-20_15:25:20_UTC [openHABian] Executing ‘openhabian-setup.sh unattended’…
2019-03-20_15:25:20_UTC [openHABian] Checking for root privileges… OK
2019-03-20_15:25:20_UTC [openHABian] Loading configuration file ‘/etc/openhabian.conf’… OK
2019-03-20_15:25:20_UTC [openHABian] Setting timezone based on IP geolocation… OK (Europe/Berlin)
2019-03-20_16:26:28_CET [openHABian] Setting locale based on openhabian.conf… OK
2019-03-20_16:26:53_CET [openHABian] Setting hostname of the base system… OK
2019-03-20_16:26:53_CET [openHABian] Setting the GPU memory split down to 16MB for headless system… OK
2019-03-20_16:26:53_CET [openHABian] Enabling Audio output… OK
2019-03-20_16:26:53_CET [openHABian] Installing basic can’t-be-wrong packages (screen, vim, …)… OK
2019-03-20_16:27:44_CET [openHABian] Installing additional needed packages… OK
2019-03-20_16:27:57_CET [openHABian] Installing additional bluetooth packages… OK
2019-03-20_16:28:02_CET [openHABian] Adding slightly tuned bash config files to system… OK
2019-03-20_16:28:02_CET [openHABian] Adding slightly tuned vim config file to system… OK
2019-03-20_16:28:02_CET [openHABian] Downloading and setting up FireMotD… OK
2019-03-20_16:28:26_CET [openHABian] Installing Zulu Embedded OpenJDK… FAILED
rm: cannot remove ‘exit’: No such file or directory
rm: cannot remove ‘1’: No such file or directory
mv: cannot stat ‘/var/tmp/jdk-new/*’: No such file or directory
FAILED
2019-03-20_16:28:27_CET [openHABian] Initial setup exiting with an error!
2019-03-20_16:42:17_CET [openHABian] Starting the openHABian initial setup.
2019-03-20_16:42:17_CET [openHABian] Storing configuration… OK
2019-03-20_16:42:17_CET [openHABian] Changing default username and password… SKIPPED
2019-03-20_16:42:17_CET [openHABian] Setting up Ethernet connection… OK
2019-03-20_16:42:17_CET [openHABian] Ensuring network connectivity… OK
2019-03-20_16:42:21_CET [openHABian] Waiting for dpkg/apt to get ready… OK
2019-03-20_16:42:28_CET [openHABian] Updating repositories and upgrading installed packages… OK
2019-03-20_16:42:35_CET [openHABian] Installing git package… OK
2019-03-20_16:42:43_CET [openHABian] Cloning myself… FAILED
2019-03-20_16:42:43_CET [openHABian] Initial setup exiting with an error!
