have since days problems with SHZ2 from innogy / LIVIZI.
First a timeout like:
2020-10-25 17:00:10.127 [hingStatusInfoChangedEvent] - ‘innogysmarthome:bridge:xxx’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed
2020-10-25 17:00:10.132 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WRT:29ce057e:12310e901bad4c9d912d1bdd09006e91’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.136 [hingStatusInfoChangedEvent] - ‘innogysmarthome:PSS:29ce057e:b819d7d783dc46eea7ed3b6b76ca8369’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.154 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WRT:29ce057e:45ae918bbab7463d9b757f41323223a2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.158 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WRT:29ce057e:468886dc5ba1492589c7a5f8f547e706’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.175 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WSD2:29ce057e:d64fa4bad3704e8fa5611fd480027082’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.178 [hingStatusInfoChangedEvent] - ‘innogysmarthome:PSSO:29ce057e:08436703589f40f2910a557794c02c76’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-10-25 17:00:10.182 [hingStatusInfoChangedEvent] - ‘innogysmarthome:VariableActuator:29ce057e:10c89e3d08d94034802cbec71b05521b’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
and so on …
And after several minutes:
2020-10-25 17:00:45.401 [hingStatusInfoChangedEvent] - ‘innogysmarthome:bridge:xxx’ changed from OFFLINE (COMMUNICATION_ERROR): java.util.concurrent.TimeoutException: Total timeout 10000 ms elapsed to ONLINE
2020-10-25 17:00:45.405 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WSD2:29ce057e:d64fa4bad3704e8fa5611fd480027082’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-10-25 17:00:45.409 [hingStatusInfoChangedEvent] - ‘innogysmarthome:PSS:29ce057e:b819d7d783dc46eea7ed3b6b76ca8369’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-10-25 17:00:45.412 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WRT:29ce057e:12310e901bad4c9d912d1bdd09006e91’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-10-25 17:00:45.420 [hingStatusInfoChangedEvent] - ‘innogysmarthome:WRT:29ce057e:468886dc5ba1492589c7a5f8f547e706’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-10-25 17:00:45.432 [hingStatusInfoChangedEvent] - ‘innogysmarthome:VariableActuator:29ce057e:10c89e3d08d94034802cbec71b05521b’ changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
System is a RPI4 and is up to date.
When the innogy bridge is online everything works. However, during the timeout nothing can executed which used innogy binding.
All other connections to ccu3, sonos, etc. works well.
Any idea or tipp?
Thanks in advance
Andreas
