Inovelli Z-Wave switches
It depends on your installation and system. Normally the documentation says how to download either the snapshots or the milestones, or the release options.
You can also see here maybe -:
Look like I have the latest Z-wave bind. Updatng my Openhab to latest release 2.3.x including updating the os did not solve the problem either. I assume this means I manually have to update a file in the installation. How do I locate the xml file to be updated? I assume this is the datebase file? cannot find any info on the forum.
Thank you.
No - you are using 2.3. As per the link I provided above, the latest is 2.4 M4.
No - as I said above, the database is included in the binding itself - it can’t easily be updated.
I can’t get a Invonelli NZW31 to work either.
nzw31
I found an OpenHAB XML file for this device on their website. What do I do with this file?
I can suggest the same solution I did above - please ensure that you are using the latest version of the binding as this device is already in the database.
I have the latest 2.4 build of the zwave binding installed and mine is still showing as Unknown Device.
Please don’t cross-post to different topics for the same problem:
