I’m using OpenHAB Version 2.5.0 (Build)
I faced this error yesterday in the openhab.log file:
2019-12-24 01:02:36.097 [ERROR] [internal.handler.RFXComBridgeHandler] - I/O Error
java.io.IOException: Input/output error in writeArray
at gnu.io.RXTXPort.writeArray(Native Method) ~[?:?]
at gnu.io.RXTXPort$SerialOutputStream.write(RXTXPort.java:1171) ~[?:?]
at org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector.sendMessage(RFXComSerialConnector.java:139) ~[bundleFile:?]
at org.openhab.binding.rfxcom.internal.handler.RFXComBridgeHandler$TransmitQueue.send(RFXComBridgeHandler.java:100) ~[bundleFile:?]
at org.openhab.binding.rfxcom.internal.handler.RFXComBridgeHandler$TransmitQueue.enqueue(RFXComBridgeHandler.java:81) ~[bundleFile:?]
at org.openhab.binding.rfxcom.internal.handler.RFXComBridgeHandler.sendMessage(RFXComBridgeHandler.java:224) [bundleFile:?]
at org.openhab.binding.rfxcom.internal.handler.RFXComHandler.handleCommand(RFXComHandler.java:84) [bundleFile:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_222]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_222]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_222]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_222]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:152) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [bundleFile:?]
at com.sun.proxy.$Proxy288.handleCommand(Unknown Source) [?:?]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:74) [bundleFile:?]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:48) [bundleFile:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:52) [bundleFile:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_222]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_222]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_222]
it seems to be related to an event, as I can see in the events.log
2019-12-24 01:02:36.004 [ome.event.ItemCommandEvent] - Item ‘VoletBureau_Shutter’ received command UP
2019-12-24 01:02:36.028 [nt.ItemStatePredictedEvent] - VoletBureau_Shutter predicted to become UP
2019-12-24 01:02:36.062 [vent.ItemStateChangedEvent] - VoletBureau_Shutter changed from NULL to 0
2019-12-24 01:02:36.191 [hingStatusInfoChangedEvent] - ‘rfxcom:bridge:5dac2b60’ changed from ONLINE to OFFLINE (COMMUNICATION_ERROR): Input/output error in writeArray
2019-12-24 01:02:36.197 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:2cd957f2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.201 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:6afdd7b0’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.205 [hingStatusInfoChangedEvent] - ‘rfxcom:lighting2:5dac2b60:31568978_2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.208 [hingStatusInfoChangedEvent] - ‘rfxcom:lighting2:5dac2b60:31568978_1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.216 [hingStatusInfoChangedEvent] - ‘rfxcom:lighting2:5dac2b60:31568978_0’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.219 [hingStatusInfoChangedEvent] - ‘rfxcom:lighting2:5dac2b60:31568978_3’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.221 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:5ec28541’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.223 [hingStatusInfoChangedEvent] - ‘rfxcom:temperaturehumidity:5dac2b60:3’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.229 [hingStatusInfoChangedEvent] - ‘rfxcom:temperaturehumidity:5dac2b60:2’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.234 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:87df3086’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.238 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:83bf44c8’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.241 [hingStatusInfoChangedEvent] - ‘rfxcom:temperaturehumidity:1377693c’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.245 [hingStatusInfoChangedEvent] - ‘rfxcom:temperaturehumidity:5dac2b60:1’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2019-12-24 01:02:36.248 [hingStatusInfoChangedEvent] - ‘rfxcom:rfy:3a6fa9c6’ changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
I saw some other people having this issue, but not with RFXCOM. So maybe it’s not RFXCOM related.
I’m posting this to share the issue, and maybe get some ideas!
Thanks in advance!
