frontail docker command:
/bin/sh -c frontail --disable-usage-stats --ui-highlight --ui-highlight-preset /usr/local/lib/node_modules/frontail/preset/${FRONTAIL_THEME}.json --theme ${FRONTAIL_THEME} -l 2000 -n 200 ${FRONTAIL_OPTS} /var/log/openhab/events.log /var/log/openhab/openhab.log
Hi!
Can you write how upgrade to OH 4?
The part
image: openhab/openhab:latest
which is already in there should do the trick, doesnāt it? At least in my case it worked.
Hi!
Iām trying to do your same configuration but with influxdb v2 and Iām having problems with influx persistence.
Can someone help me?
I know that, at some point in time, I have to do the switch as well and then update the instruction above. But so far I have not yet started this.
If youāve had any success, let me know.
Hi, Iām currently running OH 4.1.1, influxDB2 2.7.5, Grafana 10.2.3 + Portainer + Duplicati. All dockerized. Production still on old notebook Windows, VirtualBox with Ubuntu, docker_compose stack, updating occasionally. I am playing with RPI and better management (all from to portaine, but I donāt have much time to complete and migrate, so waiting for an āeventā that will force me.
What kinds of problems do you have?
Maybe you can post your configuration and docker-compose.yml. Iād like to try this once I have some free time.
Sure (please note Iām running two different instances of OpenHab, therefore I need to run the second one on different ports):
docker-compose.yaml
services:
influxdb2:
image: influxdb:latest
container_name: influxdb2
volumes:
- influxdb2:/var/lib/influxdb2:rw
ports:
- 8086:8086
restart: unless-stopped
grafana:
image: grafana/grafana
container_name: grafana
# network_mode: host
volumes:
- grafana-storage:/var/lib/grafana
environment:
- GF_SECURITY_ALLOW_EMBEDDING=true
# - GF_AUTH_ANONYMOUS_ENABLED=true
# - GF_AUTH_DISABLE_LOGIN_FORM=TRUE
ports:
- 3000:3000
depends_on:
- influxdb2
openhab:
container_name: openhab
network_mode: host
volumes:
- /etc/localtime:/etc/localtime:ro
- /etc/timezone:/etc/timezone:ro
- openhab_addons:/openhab/addons
- openhab_conf:/openhab/conf
- openhab_userdata:/openhab/userdata
environment:
- CRYPTO_POLICY=unlimited
depends_on:
- influxdb2
openhab7:
container_name: oh7
network_mode: host
volumes:
- oh7_addons:/openhab/addons
- oh7_conf:/openhab/conf
- oh7_userdata:/openhab/userdata
environment:
- OPENHAB_HTTP_PORT=8082
- OPENHAB_HTTPS_PORT=8843
depends_on:
- influxdb2
volumes:
influxdb2:
external: true
grafana-storage:
external: true
openhab_addons:
external: true
openhab_conf:
external: true
openhab_userdata:
external: true
oh7_addons:
external: true
oh7_conf:
external: true
oh7_userdata:
external: true
I was also playing (work in progress) with portainer configuration that I beleive worked, but did not yet migrate to it (please note it contains much more stuff, so that it could become the āhome automationā hub):
master.yaml
version: '4.0.1'
services:
openhab:
depends_on:
- influxdb
- mosquitto
restart: always
privileged: true
volumes:
- "/etc/localtime:/etc/localtime:ro"
- "/etc/timezone:/etc/timezone:ro"
- data_openhab_conf:/openhab/conf
- data_openhab_addons:/openhab/addons
- data_openhab_userdata:/openhab/userdata
environment:
TZ: Europe/Prague
OPENHAB_HTTP_PORT: 8080
OPENHAB_HTTPS_PORT: 8443
CRYPTO_POLICY: "unlimited"
EXTRA_JAVA_OPTS: "-Duser.timezone=Europe/Prague"
USER_ID: 999
GROUP_ID: 995
network_mode: host
openhab7:
container_name: openhab7
depends_on:
- influxdb
- mosquitto
restart: always
privileged: true
volumes:
- data_openhab7_conf:/openhab/conf
- data_openhab7_addons:/openhab/addons
- data_openhab7_userdata:/openhab/userdata
environment:
TZ: Europe/Prague
OPENHAB_HTTP_PORT: 8082
OPENHAB_HTTPS_PORT: 8843
USER_ID: 999
GROUP_ID: 995
network_mode: host
mosquitto:
image: eclipse-mosquitto:latest
container_name: mosquitto
restart: always
volumes:
- data_mosquitto_config:/mosquitto/config
- data_mosquitto_data:/mosquitto/data
- data_mosquitto_log:/mosquitto/log
ports:
- 1883:1883
- 8883:8883
environment:
TZ: Europe/Prague
influxdb:
restart: always
volumes:
- data_influxdb2:/var/lib/influxdb2
- data_influxdb2_config:/etc/influxdb2
ports:
- 8086:8086
environment:
- TZ=Europe/Prague
grafana:
volumes:
- data_grafana-storage:/var/lib/grafana
environment:
ports:
- 3000:3000
depends_on:
- influxdb
duplicati:
image: duplicati/duplicati
container_name: duplicate
environment:
- PUID=0
- PGID=0
- TZ=Europe/Prague
volumes:
- data_duplicati_backups:/backups
- data_duplicati_config:/config
- data_duplicati_data:/data
- data_grafana-storage:/source/Grafana
- data_homeassistant:/source/homeassistant
- data_influxdb2:/source/influxdb2
- data_influxdb2_config:/source/influxdb2_config
- data_mosquitto_config:/source/mosquitto_config
- data_mosquitto_data:/source/mosquitto_data
- data_mosquitto_log:/source/mosquitto_log
- data_nginx_proxy_manager_data:/source/nginx_proxy_manager_data
- data_nginx_proxy_manager_letsencrypt:/source/nginx_proxy_manager_letsencrypt
- data_openhab7_addons:/source/openhab7_addons
- data_openhab7_conf:/source/openhab7_conf
- data_openhab7_userdata:/source/openhab7_userdata
- data_openhab_addons:/source/openhab_addons
- data_openhab_conf:/source/openhab_conf
- data_openhab_userdata:/source/openhab_userdata
- data_plex_config:/source/plex_config
ports:
- 8200:8200
frontail:
image: welteki/frontail-openhab:latest
container_name: frontail
restart: always
ports:
- 9001:9001
volumes:
- data_openhab_userdata:/openhab/userdata:ro
samba:
image: dperson/samba
container_name: samba
restart: always
ports:
- "137:137/udp"
- "138:138/udp"
- "139:139/tcp"
- "445:445/tcp"
healthcheck:
disable: true
environment:
- TZ=Europe/Prague
- WORKGROUP=workgroup
- PERMISSIONS=true
- RECYCLE=false
- USER=user1;xxxxxx
- USERID=1000
- GROUPID=1000
- SHARE1=docker;/shares/docker;yes;no;no;
- SHARE2=ext;/shares/ext;yes;no;yes;
- SHARE3=log;/shares/log;yes;no;yes;
- SHARE10=duplicati_backups;/shares/data_duplicati_backups;yes;no;no;
- SHARE11=duplicati_config;/shares/duplicati_config;yes;no;no;
- SHARE12=duplicati_data;/shares/data_duplicati_data;yes;no;no;
- SHARE20=data_grafana-storage;/shares/data_grafana-storage;yes;no;no;
- SHARE21=data_homeassistant;/shares/data_homeassistant;yes;no;no;
- SHARE22=data_homer_assets;/shares/data_homer_assets;yes;no;no;
- SHARE30=influxdb2;/shares/influxdb2;yes;no;no;
- SHARE31=influxdb2_config;/shares/influxdb2_config;yes;no;no;
- SHARE32=data_influxdb2_config;/shares/influxdb2_config;yes;no;no;
- SHARE40=mosquitto_config;/shares/mosquitto_config;yes;no;no;
- SHARE41=mosquitto_log;/shares/mosquitto_log;yes;no;no;
- SHARE50=data_nginx_proxy_manager_data;/shares/data_nginx_proxy_manager_data;yes;no;no;
- SHARE51=data_nginx_proxy_manager_letsencrypt;/shares/data_nginx_proxy_manager_letsencrypt;yes;no;no;
- SHARE60=openhab7_addons;/shares/openhab7_addons;yes;no;no;
- SHARE61=openhab7_conf;/shares/openhab7_conf;yes;no;no;
- SHARE62=openhab7_userdata;/shares/openhab7_userdata;yes;no;no;
- SHARE63=openhab_addons;/shares/openhab_addons;yes;no;no;
- SHARE64=openhab_conf;/shares/openhab_conf;yes;no;no;
- SHARE65=openhab_userdata;/shares/openhab_userdata;yes;no;no;
- SHARE66=data_plex_config;/shares/data_plex_config;yes;no;no;
volumes:
- /var/lib/samba:/var/lib/samba
- /run/samba:/run/samba
- /etc:/etc
- /var/log/samba:/var/log/samba
- /var/cache/samba:/var/cache/samba
- /docker:/shares/docker
- /mnt/ext:/shares/ext
- /var/log:/shares/log
- data_duplicati_backups:/shares/duplicati_backups
- data_duplicati_config:/shares/duplicati_config
- data_duplicati_data:/shares/duplicati_data
- data_grafana-storage:/shares/data_grafana-storage
- data_homeassistant:/shares/data_homeassistant
- data_homer_assets:/shares/data_homer_assets
- data_influxdb2:/shares/influxdb2
- data_influxdb2_config:/shares/influxdb2_config
- data_mosquitto_config:/shares/mosquitto_config
- data_mosquitto_log:/shares/mosquitto_log
- data_nginx_proxy_manager_data:/shares/data_nginx_proxy_manager_data
- data_nginx_proxy_manager_letsencrypt:/shares/data_nginx_proxy_manager_letsencrypt
- data_openhab7_addons:/shares/openhab7_addons
- data_openhab7_conf:/shares/openhab7_conf
- data_openhab7_userdata:/shares/openhab7_userdata
- data_openhab_addons:/shares/openhab_addons
- data_openhab_conf:/shares/openhab_conf
- data_openhab_userdata:/shares/openhab_userdata
- data_plex_config:/shares/data_plex_config
plex:
image: linuxserver/plex
container_name: plex
network_mode: host
environment:
- PUID=1000
- PGID=1000
- VERSION=docker
# ports:
# - '32400:32400'
volumes:
- data_plex_config:/config
- /mnt/ext/plex_content:/content
restart: always
nginx-proxy-manager:
image: 'jc21/nginx-proxy-manager:latest'
container_name: nginx-proxy-manager
ports:
# These ports are in format <host-port>:<container-port>
- '80:80' # Public HTTP Port
- '443:443' # Public HTTPS Port
- '81:81' # Admin Web Port
# Add any other Stream port you want to expose
# - '21:21' # FTP
# Uncomment the next line if you uncomment anything in the section
# environment:
# Uncomment this if you want to change the location of
# the SQLite DB file within the container
# DB_SQLITE_FILE: "/data/database.sqlite"
# Uncomment this if IPv6 is not enabled on your host
# DISABLE_IPV6: 'true'
volumes:
- data_nginx_proxy_manager_data:/data
- data_nginx_proxy_manager_letsencrypt:/etc/letsencrypt
homeassistant:
image: lscr.io/linuxserver/homeassistant
container_name: homeassistant
network_mode: host
environment:
- PUID=1000
- PGID=1000
- TZ=Europe/Prague
volumes:
- data_homeassistant:/config
# homer:
# image: b4bz/homer:latest
# container_name: homer
# restart: always
# volumes:
# - data_homer_assets:/www/assets
# ports:
# - 8080:8080
rpi-monitor:
image: michaelmiklis/rpi-monitor:latest
container_name: rpi-monitor
volumes:
- /opt/vc:/opt/vc
- /boot:/boot
- /sys:/dockerhost/sys:ro
- /etc:/dockerhost/etc:ro
- /proc:/dockerhost/proc:ro
- /usr/lib:/dockerhost/usr/lib:ro
devices:
- "/dev/vchiq:/dev/vchiq"
- "/dev/vcsm-cma:/dev/vcsm-cma"
ports:
- 8888:8888
glances:
image: nicolargo/glances:latest
container_name: glances
restart: always
ports:
- 61208:61208
- 61209:61209
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
environment:
- TZ=Europe/Prague
- "GLANCES_OPT=-w"
pid: host
volumes:
data_openhab_conf:
data_openhab7_conf:
data_mosquitto_log:
data_influxdb2:
data_plex_config:
data_homeassistant:
data_homer_assets:
Update: I fixed a bug in the configuration above that prevented write access to samba shares.
Itās a Iong time, but I kind of remember I was changing some permissions and switching to āmanual userā and running smb as root to achieve it (as also different directories had different owners), but I guess it was more brute force and possibly insecureā¦ What exactly was your fix? Thanks!
I removed the user-configuration and included āall;all;allā behind all sharesā¦
ā¦ and included the read_only: false
and stdin_open:true
. Now it seems to be working (fingerās crossed). Also updated in the docker-compose.yml in the very first post of this thread.
I configured all the files for persistence (openhab_conf/persistence/influxdb.persist, openhab_conf/service/influxdb.cfg) and in InfluxDB2 I created a user āopenhabā to which I assigned an organization āorgā which has a database " openhab_db" . But I donāt know why persistence still doesnāt work. I donāt know if Iām missing something.
Log entries would help.
For InfluxDB2 you have to use a token.
My $OPENHAB_CONF/services/influxdb.cfg
# The database URL, e.g. http://127.0.0.1:8086 or https://127.0.0.1:8084 .
# Defaults to: http://127.0.0.1:8086
# url=http(s)://<host>:<port>
url=http://192.168.178.99:8086
# The name of the database user, e.g. openhab.
# Defaults to: openhab
# user=<user>
user=openhab
# The password of the database user.
# password=
# The name of the database, e.g. openhab.
# db=<database>
db=openhab
# The version of InfluxDB, V1 or V2
version=V2
# The token for version2 connections
token=1234567890abcdefghijklmnopqrstuvxyz1234567890abcdefghijklmnopqrstuvxyzABCDEFGHIJKLMNOP==
# The name of the retention Policy, e.g. openhab.
retentionPolicy=openHAB
for obvious reasons, thatās not my real token, but you get the point. you can create the token via InfluxDB Web UI. Please pay attention to the fact, that there is no password set. You donāt need no password when using the token.
db here is the name of the organisation(!) and retentionPolicy is the name of the Bucket (!)
