- Platform information:
- Hardware: RPi 3
- OS: latest stable openhabian 4.21 image 32 bit
- Java Runtime Environment: which java platform is used and what version
- openHAB version: 4.21
unfortunately I cannot install the Homegear component via the openhabian-config tool, getting this output:
2024-09-02_16:27:03_CEST [openHABian] Installing Homegear... --2024-09-02 16:27:14-- https://github.com/WiringPi/WiringPi/releases/download/2.61-1/wiringpi-2.61-1-armhf.deb
Resolving github.com (github.com)... 140.82.121.3
Connecting to github.com (github.com)|140.82.121.3|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://objects.githubusercontent.com/github-production-release-asset-2e65be/4830334/27c2a151-3fd5-4856-9f88-8a9032a5eb81?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20240902%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20240902T142714Z&X-Amz-Expires=300&X-Amz-Signature=108b03463881a9e81a0d6b2d293d31ba8b36205bdcc455ed873a02c108952e0e&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=4830334&response-content-disposition=attachment%3B%20filename%3Dwiringpi-2.61-1-armhf.deb&response-content-type=application%2Foctet-stream [following]
--2024-09-02 16:27:14-- https://objects.githubusercontent.com/github-production-release-asset-2e65be/4830334/27c2a151-3fd5-4856-9f88-8a9032a5eb81?X-Amz-Algorithm=AWS4-HMAC-SHA256&X-Amz-Credential=releaseassetproduction%2F20240902%2Fus-east-1%2Fs3%2Faws4_request&X-Amz-Date=20240902T142714Z&X-Amz-Expires=300&X-Amz-Signature=108b03463881a9e81a0d6b2d293d31ba8b36205bdcc455ed873a02c108952e0e&X-Amz-SignedHeaders=host&actor_id=0&key_id=0&repo_id=4830334&response-content-disposition=attachment%3B%20filename%3Dwiringpi-2.61-1-armhf.deb&response-content-type=application%2Foctet-stream
Resolving objects.githubusercontent.com (objects.githubusercontent.com)... 185.199.109.133, 185.199.111.133, 185.199.108.133, ...
Connecting to objects.githubusercontent.com (objects.githubusercontent.com)|185.199.109.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 53478 (52K) [application/octet-stream]
Saving to: ‘/tmp/openhabian.USW0v’
/tmp/openhabian.USW0v 100%[=====================================================================>] 52.22K --.-KB/s in 0.03s
2024-09-02 16:27:15 (1.64 MB/s) - ‘/tmp/openhabian.USW0v’ saved [53478/53478]
(Reading database ... 115910 files and directories currently installed.)
Preparing to unpack /tmp/openhabian.USW0v ...
Unpacking wiringpi (2.61) over (2.61) ...
Setting up wiringpi (2.61) ...
/bin/chown: warning: '.' should be ':': ‘root.root’
Processing triggers for man-db (2.11.2-2) ...
FAILED
Finally it returns to the config tool whit this info:
"There was an error or interruption during the execution of: │
│ "20 | Optional Components" "
Any idea what the problem is here?
