Problem since few days now. I tried some solutions found in this forum but nothing worked for me :
I wanted to upgrade openhab2 addons and nothing worked. I even purged it… so I ´d like to install it again!
Here is the error I get :
Err:1 https://dl.bintray.com/openhab/apt-repo2 stable/main arm
64 openhab2-addons all 2.5.10-1
Error reading from server - read (5: Input/output error) [IP
: 3.122.12.180 443]
E: Failed to fetch https://dl.bintray.com/openhab/apt-repo2/po
ol/main/2.5.10/openhab2-addons_2.5.10-1_all.deb Error reading
from server - read (5: Input/output error) [IP: 3.122.12.180
443]
E: Unable to fetch some archives, maybe run apt-get update or
try with --fix-missing?
Why do you need to download the addons? I believe they are only needed if you are going to install addons on a server with no Internet access.
I assume you did
sudo apt update
and
sudo apt upgrade
resp.
sudo apt upgrade openhab2 openhab2-addons
and to install
sudo apt install openhab2 openhab2-addons
In case the download with above commands does not work you manually can download the packages with e.g.
wget https://dl.bintray.com/openhab/apt-repo2 stable/main arm64 openhab2-addons all 2.5.10-1
and install the package with
sudo apt install ./openhab2-addons_2.5.10-1_all.deb
I thought I’ll do that today… others solutions didn’t work.
I forgot to say hi, sorry I wrote from my mobile. So I’d’ like to Thank you and say hello!
It is my need
Ok. It worked. Dunno what happened though
I think bintray has random errors and people have not figured out why.
