Can anyone provide a step by step tutorial to install openHAB Cloud instance on a VPS with windows 2012 server running on it.
I want steps to install OpenHAB “cloud” instance on windows
I you check
You might see that it will not run on Windows as underlying OS.
Cloud means “on somebody’s else his computer”. So if the cloud vps runs Linux, you’ll use the Linux tutorial. In your case it runs windows, use the windows tutorial. A “cloud based” version is no more than an OS (probably Linux) with openHAB installed.
No, he is talking about openHAB-cloud, aka myopenHAB
Right Sir… So, we have to install it on server running linux server only…
