Install Rule Template via Config File
Is it possible to install rule templates via config files, such as the addons.cfg file or similar? I’ve tried adding via the automations section of the addons.cfg, doing something like marketplace:123456, market:123456, or 123456 does not work. I’m currently trying this for openHAB 4.2.2.
Unfortunatelty not. You must install it through MainUI.
You can’t instantiate a rule from a tempalte except through MainUI either.
