I have uninstall the embedded MQTT broker and the MQTT binding and try to reinstall them after an openhab server reboot. I am running OpenHab 2.5.0.M3 on a window 10 PC
The MQTT Embedded Broker install log is showing a bunch of error as you could see below:
10:00:25.136 [INFO ] [.internal.service.FeaturesServiceImpl] - Adding features: openhab-misc-mqttbroker/[2.5.0.M3,2.5.0.M3]
10:00:26.487 [INFO ] [.internal.service.FeaturesServiceImpl] - Changes to perform:
10:00:26.488 [INFO ] [.internal.service.FeaturesServiceImpl] - Region: root
10:00:26.488 [INFO ] [.internal.service.FeaturesServiceImpl] - Bundles to install:
10:00:26.489 [INFO ] [.internal.service.FeaturesServiceImpl] - mvn:org.openhab.addons.bundles/org.openhab.io.mqttembeddedbroker/2.5.0.M3
10:00:26.490 [INFO ] [.internal.service.FeaturesServiceImpl] - Stopping bundles:
10:00:26.492 [INFO ] [.internal.service.FeaturesServiceImpl] - swagger-jersey2-jaxrs/1.5.8.v20160511-1038
10:00:26.493 [INFO ] [.internal.service.FeaturesServiceImpl] - reflections/0.9.10.v20160429-1435
10:00:26.494 [INFO ] [.internal.service.FeaturesServiceImpl] - io.swagger.jaxrs/1.5.8
10:00:26.497 [INFO ] [.internal.service.FeaturesServiceImpl] - com.eclipsesource.jaxrs.provider.swagger/1.1.1.201605111122
10:00:26.501 [INFO ] [.internal.service.FeaturesServiceImpl] - Installing bundles:
10:00:26.504 [INFO ] [.internal.service.FeaturesServiceImpl] - mvn:org.openhab.addons.bundles/org.openhab.io.mqttembeddedbroker/2.5.0.M3
10:00:26.582 [INFO ] [.internal.service.FeaturesServiceImpl] - Refreshing bundles:
10:00:26.583 [INFO ] [.internal.service.FeaturesServiceImpl] - com.eclipsesource.jaxrs.provider.swagger/1.1.1.201605111122 (Wired to io.swagger.jaxrs/1.5.8 which is being refreshed)
10:00:26.584 [INFO ] [.internal.service.FeaturesServiceImpl] - io.swagger.jaxrs/1.5.8 (Wired to reflections/0.9.10.v20160429-1435 which is being refreshed)
10:00:26.586 [INFO ] [.internal.service.FeaturesServiceImpl] - reflections/0.9.10.v20160429-1435 (Should be wired to: com.google.guava/18.0.0 (through [reflections/0.9.10.v20160429-1435] osgi.wiring.package; resolution:=optional; filter:="(osgi.wiring.package=com.google.common.base)"))
10:00:26.587 [INFO ] [.internal.service.FeaturesServiceImpl] - swagger-jersey2-jaxrs/1.5.8.v20160511-1038 (Wired to io.swagger.jaxrs/1.5.8 which is being refreshed)
10:00:26.808 [INFO ] [.internal.service.FeaturesServiceImpl] - Starting bundles:
10:00:26.809 [INFO ] [.internal.service.FeaturesServiceImpl] - org.openhab.io.mqttembeddedbroker/2.5.0.M3
10:00:26.828 [INFO ] [broker.internal.EmbeddedBrokerService] - Broker persistence file: mqttembedded.bin
10:00:26.833 [INFO ] [io.moquette.broker.Server ] - Configuring message interceptors...
10:00:26.835 [INFO ] [quette.interception.BrokerInterceptor] - Initializing broker interceptor. InterceptorIds=[]
10:00:26.837 [INFO ] [io.moquette.broker.Server ] - Using default SSL context creator
10:00:26.839 [INFO ] [io.moquette.broker.Server ] - An io.moquette.broker.security.AcceptAllAuthenticator authenticator instance will be used
10:00:26.840 [INFO ] [io.moquette.broker.Server ] - Authorizator policy io.moquette.broker.security.PermitAllAuthorizatorPolicy instance will be used
10:00:26.841 [INFO ] [io.moquette.persistence.H2Builder ] - Initializing H2 store
10:00:26.888 [ERROR] [org.openhab.io.mqttembeddedbroker ] - bundle org.openhab.io.mqttembeddedbroker:2.5.0.M3 (295)[org.openhab.io.mqttembeddedbroker.internal.EmbeddedBrokerService(296)] : The activate method has thrown an exception
java.lang.IllegalArgumentException: Could not deserialize [-84, -19, 0, 5, 115, 114, 0, 45, 105, 111, 46, 109, 111, 113, 117, 101, 116, 116, 101, 46, 98, 114, 111, 107, 101, 114, 46, 115, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, 115, 46, 83, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, -47, 11, -117, 54, 80, -6, 26, -58, 2, 0, 3, 76, 0, 8, 99, 108, 105, 101, 110, 116, 73, 100, 116, 0, 18, 76, 106, 97, 118, 97, 47, 108, 97, 110, 103, 47, 83, 116, 114, 105, 110, 103, 59, 76, 0, 12, 114, 101, 113, 117, 101, 115, 116, 101, 100, 81, 111, 115, 116, 0, 37, 76, 105, 111, 47, 110, 101, 116, 116, 121, 47, 104, 97, 110, 100, 108, 101, 114, 47, 99, 111, 100, 101, 99, 47, 109, 113, 116, 116, 47, 77, 113, 116, 116, 81, 111, 83, 59, 76, 0, 11, 116, 111, 112, 105, 99, 70, 105, 108, 116, 101, 114, 116, 0, 40, 76, 105, 111, 47, 109, 111, 113, 117, 101, 116, 116, 101, 47, 98, 114, 111, 107, 101, 114, 47, 115, 117, 98, 115, 99, 114, 105, 112, 116, 105, 111, 110, 115, 47, 84, 111, 112, 105, 99, 59, 120, 112, 116, 0, 20, 101, 109, 98, 101, 100,... [1.4.199/0]
at org.h2.mvstore.DataUtils.newIllegalArgumentException(DataUtils.java:857) ~[?:?]
at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:376) ~[?:?]
at org.h2.mvstore.type.ObjectDataType$SerializedObjectType.read(ObjectDataType.java:1547) ~[?:?]
at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:231) ~[?:?]
at org.h2.mvstore.type.ObjectDataType.read(ObjectDataType.java:114) ~[?:?]
at org.h2.mvstore.Page$Leaf.readPayLoad(Page.java:1551) ~[?:?]
at org.h2.mvstore.Page.read(Page.java:695) ~[?:?]
at org.h2.mvstore.Page.read(Page.java:238) ~[?:?]
at org.h2.mvstore.MVStore.readPage(MVStore.java:2187) ~[?:?]
at org.h2.mvstore.MVMap.readPage(MVMap.java:554) ~[?:?]
at org.h2.mvstore.MVMap.readOrCreateRootPage(MVMap.java:570) ~[?:?]
at org.h2.mvstore.MVMap.setRootPos(MVMap.java:564) ~[?:?]
at org.h2.mvstore.MVStore.openMap(MVStore.java:548) ~[?:?]
at org.h2.mvstore.MVStore.openMap(MVStore.java:507) ~[?:?]
at org.h2.mvstore.MVStore.openMap(MVStore.java:488) ~[?:?]
at io.moquette.persistence.H2SubscriptionsRepository.<init>(H2SubscriptionsRepository.java:22) ~[?:?]
at io.moquette.persistence.H2Builder.subscriptionsRepository(H2Builder.java:51) ~[?:?]
at io.moquette.broker.Server.startServer(Server.java:167) ~[?:?]
at org.openhab.io.mqttembeddedbroker.internal.EmbeddedBrokerService.startEmbeddedServer(EmbeddedBrokerService.java:310) ~[?:?]
at org.openhab.io.mqttembeddedbroker.internal.EmbeddedBrokerService.initialize(EmbeddedBrokerService.java:195) ~[?:?]
at org.openhab.io.mqttembeddedbroker.internal.EmbeddedBrokerService.activate(EmbeddedBrokerService.java:159) ~[?:?]
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) ~[?:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) ~[?:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) ~[?:?]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) ~[?:?]
at com.eclipsesource.jaxrs.publisher.internal.ResourceTracker.addingService(ResourceTracker.java:39) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:941) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerAdding(ServiceTracker.java:870) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.trackAdding(AbstractTracked.java:256) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:229) ~[?:?]
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:901) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) ~[?:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) ~[?:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) ~[?:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:666) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:432) ~[?:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:665) ~[?:?]
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:338) ~[?:?]
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:382) ~[?:?]
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:49) ~[?:?]
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:264) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169) ~[?:?]
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:482) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:415) ~[?:?]
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232) ~[?:?]
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:908) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:213) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:120) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:112) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:168) ~[?:?]
at org.eclipse.osgi.container.Module.publishEvent(Module.java:476) ~[?:?]
at org.eclipse.osgi.container.Module.start(Module.java:467) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:402) ~[?:?]
at org.apache.karaf.features.internal.service.BundleInstallSupportImpl.startBundle(BundleInstallSupportImpl.java:165) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.startBundle(FeaturesServiceImpl.java:1153) ~[?:?]
at org.apache.karaf.features.internal.service.Deployer.deploy(Deployer.java:1036) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.doProvision(FeaturesServiceImpl.java:1062) ~[?:?]
at org.apache.karaf.features.internal.service.FeaturesServiceImpl.lambda$doProvisionInThread$13(FeaturesServiceImpl.java:998) ~[?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.lang.ClassNotFoundException: io.moquette.broker.subscriptions.Subscription cannot be found by com.h2database.mvstore_1.4.199
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:484) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:395) ~[?:?]
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:387) ~[?:?]
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:150) ~[?:?]
at java.lang.ClassLoader.loadClass(Unknown Source) ~[?:?]
at java.lang.Class.forName0(Native Method) ~[?:?]
at java.lang.Class.forName(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.resolveClass(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.readNonProxyDesc(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.readClassDesc(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.readOrdinaryObject(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.readObject0(Unknown Source) ~[?:?]
at java.io.ObjectInputStream.readObject(Unknown Source) ~[?:?]
at org.h2.mvstore.type.ObjectDataType.deserialize(ObjectDataType.java:374) ~[?:?]
... 96 more
10:00:26.930 [INFO ] [broker.internal.EmbeddedBrokerService] - Broker persistence file: mqttembedded.bin
10:00:26.931 [INFO ] [io.moquette.broker.Server ] - Configuring message interceptors...
10:00:26.936 [INFO ] [quette.interception.BrokerInterceptor] - Initializing broker interceptor. InterceptorIds=[]
10:00:26.936 [INFO ] [io.moquette.broker.Server ] - Using default SSL context creator
10:00:26.937 [INFO ] [io.moquette.broker.Server ] - An io.moquette.broker.security.AcceptAllAuthenticator authenticator instance will be used
10:00:26.940 [INFO ] [io.moquette.broker.Server ] - Authorizator policy io.moquette.broker.security.PermitAllAuthorizatorPolicy instance will be used
10:00:26.941 [INFO ] [io.moquette.persistence.H2Builder ] - Initializing H2 store
10:00:26.943 [ERROR] [org.openhab.io.mqttembeddedbroker ] - bundle org.openhab.io.mqttembeddedbroker:2.5.0.M3 (295)[org.openhab.io.mqttembeddedbroker.internal.EmbeddedBrokerService(296)] : The activate method has thrown an exception
java.lang.IllegalStateException: The file is locked: nio:C:\Users\regis\openhab2\userdata\mqttembedded.bin [1.4.199/7]
at org.h2.mvstore.DataUtils.newIllegalStateException(DataUtils.java:883) ~[?:?]
at org.h2.mvstore.FileStore.open(FileStore.java:166) ~[?:?]
at org.h2.mvstore.MVStore.<init>(MVStore.java:390) ~[?:?]
at org.h2.mvstore.MVStore$Builder.open(MVStore.java:3343) ~[?:?]
at io.moquette.persistence.H2Builder.initStore(H2Builder.java:40) ~[?:?]
at io.moquette.broker.Server.startServer(Server.java:166) ~[?:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:756) ~[?:?]
Caused by: java.nio.channels.OverlappingFileLockException
at sun.nio.ch.SharedFileLockTable.checkList(Unknown Source) ~[?:?]
at sun.nio.ch.SharedFileLockTable.add(Unknown Source) ~[?:?]
at sun.nio.ch.FileChannelImpl.tryLock(Unknown Source) ~[?:?]
at org.h2.store.fs.FileNio.tryLock(FilePathNio.java:121) ~[?:?]
at java.nio.channels.FileChannel.tryLock(Unknown Source) ~[?:?]
at org.h2.mvstore.FileStore.open(FileStore.java:163) ~[?:?]
... 56 more
10:00:26.951 [WARN ] [org.openhab.io.mqttembeddedbroker ] - FrameworkEvent WARNING - org.openhab.io.mqttembeddedbroker
org.osgi.framework.ServiceException: org.apache.felix.scr.impl.manager.SingleComponentManager.getService() returned a null service object
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:232) ~[?:?]
at java.util.concurrent.FutureTask.run(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) ~[?:?]
at java.lang.Thread.run(Unknown Source) ~[?:?]
10:00:27.017 [INFO ] [.internal.service.FeaturesServiceImpl] - Done.
10:00:27.063 [INFO ] [smarthome.event.ExtensionEvent ] - Extension 'misc-mqttbroker' has been installed.
