Andrew_Rowe
(Andrew Rowe)
November 11, 2019, 12:04pm
19
this is your issue. Please follow steps in linked thread for workaround. The issue is now solved but the change did not make it in time for M4 release. Any of the snapshots shortly after M4 should contain the fix
link to git hub issue
https://github.com/openhab/openhab2-addons/issues/5527
more info
Restarting OpenHAB has caused the embedded mqtt server to go offline again. This time I do not see the same error message about a file lock causing the problem
unstalling the broker caused this
9:15:40.238 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mqtt:systemBroker:embedded-mqtt-broker' changed from OFFLINE (CONFIGURATION_ERROR): The system connection with the name embedded-mqtt-broker doesnt exist anymore. to REMOVING
19:15:40.239 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - 'mq…
