I run openHAB on my DS216. I wanted a fresh installation and deinstalled it.
After that - I can not install it anymore. When selecting the SPK file
openHAB-2.3.0.001-SNAPSHOT-syno-noarch-0.001.spk
(from github) during manual installation, I get a Synology message: “Operation failed”.
I run
DSM 6.1.5-15254
And Java 8 is installed and running.
Do you have any idea what could prevent reinstallation?
I tried also:
openHAB-2.2.0.010-syno-noarch-0.001.spk
Also make sure you stopped the current openHAB version, deinstalled it proper… in my case after stopping it , the openHAB was still running and i had to stop manually via SSH command…
Thank you for your answer. I looked with
ps -A | grep open
command. There is no openHAB process running.
I must say, that openHAB worked with the installed java8 package.
Only after deinstalling and trying to install again via spk … I get this strange error. It seems not an openHAB error, but a Synology message.
