Hi there!
I am new to openHAB, tried before Homegenie and Domoticz and decieded to try openHAB.
I am using a Raspi2 with Z-Wave GPIO Card.
I have downloaded Raspi-Wheezy and installed it.
Next step was installing openHAB as explained here:
After that i tried to access openHAB via Browser by typing in:
http://192.168.1.2:8080/openhab.app
and getting to following error:
HTTP ERROR 500
Problem accessing /openhab.app. Reason:
Sitemap ‘default’ could not be foundCaused by:org.openhab.ui.webapp.render.RenderException: Sitemap ‘default’ could not be found
at org.openhab.ui.webapp.internal.servlet.WebAppServlet.service(WebAppServlet.java:115)
at org.eclipse.equinox.http.servlet.internal.ServletRegistration.service(ServletRegistration.java:61)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.processAlias(ProxyServlet.java:128)
at org.eclipse.equinox.http.servlet.internal.ProxyServlet.service(ProxyServlet.java:60)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:848)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:598)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:486)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:231)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1065)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:413)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:192)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:999)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:117)
at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:250)
at org.eclipse.jetty.server.handler.HandlerCollection.handle(HandlerCollection.java:149)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:111)
at org.eclipse.jetty.server.Server.handle(Server.java:350)
at org.eclipse.jetty.server.AbstractHttpConnection.handleRequest(AbstractHttpConnection.java:454)
at org.eclipse.jetty.server.AbstractHttpConnection.headerComplete(AbstractHttpConnection.java:890)
at org.eclipse.jetty.server.AbstractHttpConnection$RequestHandler.headerComplete(AbstractHttpConnection.java:944)
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:630)
at org.eclipse.jetty.http.HttpParser.parseAvailable(HttpParser.java:230)
at org.eclipse.jetty.server.AsyncHttpConnection.handle(AsyncHttpConnection.java:77)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint.handle(SelectChannelEndPoint.java:606)
at org.eclipse.jetty.io.nio.SelectChannelEndPoint$1.run(SelectChannelEndPoint.java:46)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:603)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:538)
at java.lang.Thread.run(Thread.java:744)
After searching the wiki and install-instructions i found no real solutuion at all.
Searched via goggle, i found that i have to install the demo-setup but don´t really found
where to extract it.
Tried first to extract it to opt/openhab, after that to etc/openhab…not working,
still the same error.
Any ideas???..pls help.
Regards
OCB
