my first post in this community unfortunately as result of an unsuccesfull installation.
I followed your installation guide (openHABian 1.4.1) but after waiting for two hours after
Wait approximately 15-45 minutes for openHABian to do its magic
the attached TV-screen is black and I can’t connect to http://openhabianpi:8080 either.
My Pi2 is attached via LAN-cable.
We really need some more information.
What happens if you reboot - is the screen still black?
Does the screen show anything at all during boot up?
Is the tv connected by hdmi? and is it selected in HDMI mode?
I see a boot screen on my TV attached via HDMI. Several lines of code before the screen turns to black there is something like “daily apt”. Thats it. How can I log in with a black screen even with a keyboard attached?
Unfortunately I’m no LINUX-wiz. That’s exactly why i used habian.
Do you have another monitor (or borrow) you could try? You could also use an analog video lead to an analog input on a tv or monitor as another option to try instead of the hdmi connection.
Another question - have you booted up a raspberry pi before and been able to see the screen correctly with your setup?
This
sounds like the boot did not complete. It might be worth erasing the SD card and trying again in case something has corrupted. Have you checked your download checksum is good?
Just put the SD into a Pi 3 with exactly the same result.
Why is this the only system (I have 3 PI’s running on the same LAN ) having problems with the internet connection?
I’m giving it another try now with WiFi.
The internet connection must at least work regarding the system time because in both cases the time displayed was correct and is not possible without any internet connection.
At the moment “Daily apt upgrade and clean activities” are running.
