I want to install the OpenHAB-2.1.0.003-SNAPSHOT-DSM6-syno-noarch-0.001.spk on my DS214+.
(DSM 6.1-15047 Update 1, Java is installed). But the installation isn’t complete. After the installation-process i found only this three files and opnhab can’t be started
I now have openHAB-2.0.0.001-DSM6-syno-noarch-0.001 running on my DS414. No other version 2 release of openHAB for Synology would work for me. Your results may vary.
One other hint. Your DS214+ has the same armadaxp chip set as my DS414. As of DSM6, Synology switched the required Java version from soft float for armadasp & armada370. Once I changed Oracle Java to hard float (hflt), the karaf errors in the Synology log ceased and the web interface worked.
