I have installed Openhab2 on a windows 10.
I have installed binding NHC and openhab cloud and all is ok.
I discover all my niko home programmation (all items are found and functionnaly on Openhab2)
Then, i go on my google assistant with my s8 i go on add device et put add openhab. i have message that association ok but nothing appear in settings google assistant no room nothing. In device i dont see openhab installed.
In openhab cloud, i see a message that google assistant is authorized.
When i say sync device i have message no assistant installed…?
I try to delete all items to let only 1 switch but always same problem.
Thx for your answer. When i go on repertory item i have only 1 file (readme) and nothing else.-
I see my items only in paperui ->config->item
Where i can add tag?
There is no real need to do textual configuration.
Make sure ‘REST Documentation’ is installed in paperUI. You can find it under Add-ons, Misc. Go to the rest api under hostname:8080/doc. Under items, you find PUT tag (last one under items). Just fill in your itemname and tag and apply.
I agree textual configuration may be easier in the long run, but I have it set up this way myself.
