Ralf
(Ralf Klüber)
November 20, 2018, 4:42pm
1
today I switched from 2.1 to 2.3. I restarted. Everything is smooth and runs. However I cant get HomeKit Binding installed.
I recognized it is still v2.1. When checking this I saw I only have 2.1 plugins at all. No 2.3. Is this supposed to be, or is something still buggy in my environment?
I did:
Install 2.3 from zipfile
copied all the conf folder from 2.1 to 2.3
started openhab again.
When I go into the console it says OH2.3. So update worked. But in PaperUI no 2.3 plugins at all.
Any hints?
Regards
Ralf
H102
(CM6.5 H102)
November 20, 2018, 4:50pm
2
Please provide the following info.
Platform information:
Hardware: CPUArchitecture/RAM/storage
OS: what OS is used and which version
Java Runtime Environment: which java platform is used and what version
Ralf
(Ralf Klüber)
November 20, 2018, 6:29pm
3
# uname -a
Linux odroid 3.8.13.16 #1 SMP PREEMPT Tue Feb 11 10:47:21 BRST 2014 armv7l armv7l armv7l GNU/Linux
# cat /proc/meminfo
MemTotal: 2071520 kB
MemFree: 834736 kB
Buffers: 141136 kB
Cached: 545816 kB
SwapCached: 0 kB
# java -version
java version "1.8.0_144"
Java(TM) SE Runtime Environment (build 1.8.0_144-b01)
Java HotSpot(TM) Client VM (build 25.144-b01, mixed mode)
Dim
(Angelos)
November 20, 2018, 6:45pm
4
Ralf:
How was 2.1 installed?
Manually or using an apt package?
Where did you manually install 2.3? (in which directory)?
Ralf
(Ralf Klüber)
November 20, 2018, 9:27pm
5
I downloaded the ZIP file and unzipped in /home/openhab. Both for 2.1 and for 2.3.
/home/openhab/2.1
/home/openhab/2.3
cd /home/openhab
ln -s 2.3 current
cd current
cp -R …/conf/* conf/
my init script starts the OH installation in
/home/openhab/current
Dim
(Angelos)
November 20, 2018, 9:30pm
6
Ralf:
did you copy anything else also from 2.1 over to 2.3? (maybe the userdata subfolder)?
permissions are correctly setup I assume.
strange that you keep seeing 2.1 content on the 2.3 PaperUI. This could happen if you had copied over the old userdata contents
Ralf
(Ralf Klüber)
November 20, 2018, 9:34pm
7
No, only config folder with all subfolders.
Dim
(Angelos)
November 20, 2018, 9:37pm
8
do you have any environment variables set?
echo $OPENHAB_CONF
echo $OPENHAB_HOME
echo $OPENHAB_RUNTIME
echo $OPENHAB_USERDATA
Ralf
(Ralf Klüber)
November 20, 2018, 10:06pm
9
None. Seems not a good thing …?
Dim
(Angelos)
November 20, 2018, 10:08pm
10
no, it’s normal when using a manual installation method… it’s ok
the OH2 startup scripts take case of that stuff, so you don’t have to.
by the way: Why not a packaged installation? (less headaches)
