Hello!
I’m running OpenHAB 2.5.3 via docker (openhab/openhab:2.5.3-amd64-debian). I’m attempting to install the homie binding via configuration files. According to the documentation I should be able to locate the binding’s name via the console. However nothing is found named homie…
openhab> feature:list | grep homie
openhab>
As an alternative, I should be able to discover the name via the URL used in the binding documentation, i.e. https://www.openhab.org/addons/bindings/mqtt.homie/
. But using mqtt.homie
is not found when openhab starts up. Also tried just plain homie
without any luck.
2020-03-29 21:25:02.964 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-mqtt.homie'
2020-03-29 21:26:02.922 [ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-homie'
Help.
Thanks,
-Chris
