Installing Influxdb+grafana using openhabian-config does not work and results in an error message
  • Platform information:
    • Hardware:amd64/4GB/SSD
    • OS: Debian 12
    • Java Runtime Environment: zulu17
    • openHAB version: 4.0.3
  • Issue of the topic: Installing Influxdb+grafana using openhabian-config does not work and results in an error message:
Ign:5 https://repos.influxdata.com/debian bookworm InRelease
Fehl:6 https://repos.influxdata.com/debian bookworm Release
  404  Not Found [IP: 18.155.145.52 443]
OK:7 https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable InRelease
Paketlisten werden gelesen…
FAILED (update apt lists)
I started with a netinstall debian with systemtweaks and ssh server enabled. Then I used the git repository described on:
(openHABian | openHAB)
for installing openhab. Last I used openhabian-config to install “influxdb+grafana”
Installing Influxdb+grafana is running in an error. I found the solution in changing the influxdb repository entry in apt configuration file /etc/apt/sources.list.d/influxdb.list:
I changed “bookworm stable”
 deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian bookworm stable
to “stable main”
deb [signed-by=/usr/share/keyrings/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main
like it is shown on the incluxdb repository “homepage”:
InfluxData - Package Repository
Now downloading and installing influxdb works like a charm.
It looks like a bug in automated generating the repository file for influxdb. Where can I open a ticket?
New issues can be opened at Issues · openhab/openhabian · GitHub
Then you also can delete it. “stable main” points to bookwork at time of writing: Debian -- Debian Releases . This then will use the influxdb of the ( bookworm ) distribution
The idea of the extra .list file was/is to install a more up to date influxdb. As at this moment it is not available / the repo is not available you get the error message. See Bookworm readyness · Issue #1788 · openhab/openhabian · GitHub
