Hi, I installed OH 2 on my ODROID-XU4 with Ubuntu 15.04 and it was running smoothly. Then I tried to get it running as a service. The installation process (openhab:install-service) runs smoothly with just 2 warnings. When I try to start it that darn syntax error showed up again!
Syntax error: “(” unexpected
Couldn’t get it running as a service. I decided to write my own bash script for running it as a background service. I made a copy of the /etc/init.d/skeleton file and named it openhab. I will put my script below because it might be useful to others.
#!/bin/sh
# kFreeBSD do not accept scripts as interpreters, using #!/bin/sh and sourcing.
if [ true != "$INIT_D_SCRIPT_SOURCED" ] ; then
set "$0" "$@"; INIT_D_SCRIPT_SOURCED=true . /lib/init/init-d-script
fi
### BEGIN INIT INFO
# Provides: OpenHAB 2
# Required-Start: $remote_fs $syslog
# Required-Stop: $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: OpenHAB 2 runtime service
# Description: To start the OpenHAB service: openhab start
# To stop the OpenHAB service: openhab stop
# To restart the OpenHAB service: openhab restart
### END INIT INFO
# Author: Vincent Broeke
PIDFILE=/var/run/openhab.pid
start() {
if [ -f $PIDFILE ] && kill -0 $(cat $PIDFILE) ; then
echo "OpenHAB already running!"
return 1
fi
echo "Starting OpenHAB..."
/opt/openhab/runtime/karaf/bin/karaf > /dev/null &echo $! > $PIDFILE
echo "OpenHAB started."
stop() {
if [ ! -f $PIDFILE ] || ! kill -0 $(cat $PIDFILE) ; then
echo "OpenHAB is not running."
return 1
fi
echo "Stopping OpenHAB..."
kill -15 $(cat $PIDFILE) && rm -f $PIDFILE
echo "OpenHAB stopped."
case "$1" in
start)
start
stop)
stop
restart)
stop
start
echo "Usage: $0 {start|stop|restart}"
esac
exit 0
UPDATE 1:
I found out that the above script is a depricated way of running services on a linux machine. The script for Raspberry PI’s is working fine for ODROID’s too! See the documentation for getting started with openHAB 2.
